Thread: Need help with 2004 pontiac grand prix gtp supercharged
Results 1 to 5 of 5
  1. #1 Need help with 2004 pontiac grand prix gtp supercharged
    Feb 2016
    I've been battling this issue since November of last year and I'm out of ideas of what could be wrong. At first my car would stall after I would come to a stop without any warning, then when I started it up and shifted to reverse the car shut off, now where it won't even turn over anymore. I've changed the fuel pump, fuel filter, and tested the fuel injectors and they are fine. Also used a fuel system cleaner and sea foam on the car. The car only has 90,000 miles on it, Any ideas would be great thank you.
    Sent from my SM-G386T using Tapatalk
  2. #2 Re: Need help with 2004 pontiac grand prix gtp supercharged
    The stall at first sounds like a dead crank sensor. They are known to fail without setting codes.
  3. #3 Re: Need help with 2004 pontiac grand prix gtp supercharged
    SWPA
    Quote Originally Posted by lilrunna4me View Post
    If the car won't turn over then its not even cranking. If you mean it won't start then yes look toward the crank sensor.
    You need 4 things to start a engine. Fuel, spark, compression, and timing. If one is missing the car won't run.
  4. #4 Re: Need help with 2004 pontiac grand prix gtp supercharged
    Feb 2016
    Okay I'll look there and before all this happened my coolant hose some how got close to my belt and pretty much cut through the hose and was leaking. Could that have shorted the censor?
  5. #5 Re: Need help with 2004 pontiac grand prix gtp supercharged
    Feb 2016
    Thanks for the tip.
  1. 2007 Pontiac Grand Prix GT 3.8L Supercharged.
    By 2007GrandPrixGT in forum Engine
    Last Post: 05-13-2012, 11:46 AM
  2. Replies: 11
    Last Post: 02-23-2012, 11:17 AM
  3. 1997 3.8 supercharged Pontiac Grand Prix,
    By Seansta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2011, 06:13 PM
  4. Trying to mod my 2000 Pontiac Grand Prix GTP Supercharged
    By grandprixgtpsc00 in forum General Tech Discussion
    Last Post: 01-31-2011, 08:21 PM
