Thread: Driver wiper out of track?
Results 1 to 11 of 11
  1. #1 Driver wiper out of track?
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Was driving to town, about 20 or so miles today, and my driver side wiper did this:
    Really confused, as I can push it back to place, when car is in park and it works fine, get on highway/interstate going 60-65 and it does that after a couple wipes of the windshield. I fixed it when i parked, and tried it again and it did it again, ended up holding the wiper when i tried using the wiper blade, and then let go when it was supposed to go back down and it went right where it was supposed to go.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: Driver wiper out of track?
    pop the cap off the wiper arm at the bottom, it covers the nut. wipers off and parked, tighten the nut up.
  3. #3 Re: Driver wiper out of track?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    Exact same thing happened to me, I believe it's a 10mm, fixed it right up.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  4. #4 Re: Driver wiper out of track?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    It's a 13mm. I used to check mine every couple months because I had the same thing happen at 75mph in a rainstorm. I removed the nut and reinstalled with a nylon locking nut to keep it from loosening. Don't go too tight so you don't stretch or break the stud.
    I also use 20" wipers, they seem more stable and wipe better than the standard 22", which seems to flutter around and not wipe anything at highway speeds.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Driver wiper out of track?
    Jun 2015
    Oops my bad, get that 10 and 13 mixed up all the time. I'll have to keep the wiper length in mind next time I get wipers...
  6. #6 Re: Driver wiper out of track?
    Aug 2012
    Brainerd, MN
    Good, just loose, ill have to tighten it down tomorrow sometime, was kind of a shock to me going about 65, hit my wipers, then it does that, i took a picture and sent it to some people with "wtf" as the text
  7. #7 Re: Driver wiper out of track?
    Jun 2015
    Me too, I was doing 75 on the interstate and it was pouring buckets of rain when it happened a second time because I was scared of breaking something, so I didn't tighten it enough the first time. Ever grateful that I carry a stocked tool box and a socket set in my trunk, lol.
  8. #8 Re: Driver wiper out of track?
    Aug 2012
    Brainerd, MN
    I just pulled over next time i had the chance, and pushed it back to where it should be, tried the wipers and it seemed fine, it happened again and at a red light you just see my window go down, hold the wiper, then the passenger side started going down and I let go and it went back down, probably funny if you seen it when its 20 degrees out.
  9. #9 Re: Driver wiper out of track?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    If the wipers park in the vertical position it's most likely the parking tab on the wiper motor itself. There's a tab in the bottom pic that points up. Mine was bent down thus causing the wipers to keep going until it parked at the extended position.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  10. #10 Re: Driver wiper out of track?
    oh buck, thats a whole different issue. that when you turn them off and they park in the middle of the glass.
  11. #11 Re: Driver wiper out of track?
    Aug 2011
    Gahanna, Ohio
    yeah I know. Just throwing that out there
  1. Driver side windshield wiper swings out past the edge of windshield
    By jcvv in forum General Grand Prix Discussion
    Last Post: 04-13-2014, 02:51 PM
  2. WTB 97-02 coupe driver door shell and driver fender
    By logan809 in forum Wanted To Buy - Parts
    Last Post: 02-18-2012, 08:41 PM
  3. Driver's Side Windshield Wiper Stopped Working.
    By Chaotic94 in forum General Tech Discussion
    Last Post: 02-27-2011, 05:29 PM
  4. Driver side wiper arm slips down to the side mirror
    By kappian in forum General Tech Discussion
    Last Post: 04-05-2010, 08:43 PM
  5. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
