Thread: Door panel clips
Results 1 to 20 of 22
  1. #1 Door panel clips
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    Could someone point me in the right direction of the clips I need? My window regulator went in the rear so I need to take them off and have some that don't stay clipped so figure it's the perfect time to replace them. I'm just not sure what ones are the exact fit.
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  2. #2 Re: Door panel clips
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #3 Re: Door panel clips
    Buffalo, NY
    Thanks. I found those searching google but wanted to be sure before I ordered them and then had some more useless stuff sitting around.
  4. #4 Re: Door panel clips
    Jan 2014
    AR
    If you're working on a 97-03 GP...
    On the left is an original clip. In the center is the new clips I bought at O'Reilly's (they sell paint stuff too) in bulk. On the right is an incorrect clip that works. Most clips you find new, like the ones on that link, are longer than stock. Only a few on the top row need to be trimmed. Some may contact the glass if not.
  5. #5 Re: Door panel clips
    Dec 2014
    Maryland
    i read the reviews first and there was a few GP owners that said they worked so i bought em...just ain't tried em yet.
    Verified Purchase After 2 speaker installs my car door panels were all barely hanging onto my 98 Pontiac Grand Prix.
    I looked everywhere for these at the brick and mortar auto stores. I could only find 3 at time if they had them and they were expensive.
    These fit the bill and I had enough to fully replace 2 front doors with extras to selectively replace worn clips on the rear doors.
  6. #6 Re: Door panel clips
    Buffalo, NY
    idrivejunk, that's good info thanks. Basically if I cut them at the break in the ridges it's be a good length?
  7. #7 Re: Door panel clips
    Jan 2014
    AR
    I just noticed that break in the ridges same time you did, Dude. Came to the same conclusion too. Looks right to me. Might be a little harder to stab without the point, just be careful lining them up or carve a point. These hold ferociously like the stockers and might make 2-3 uses, in my experience. If I had to venture a guess what brand, it'd be Au-Ve-Co, but I don't know the manufacturer's name on these. I have seen some aftermarket versions that were too off-white and brittle. I have seen some that are bright white and too brittle. These are good as any I've seen.
  8. #8 Re: Door panel clips
    Dec 2014
    Maryland
  9. #9 Re: Door panel clips
    Dec 2014
    Maryland
    after doing research, these clips are for 97 GP
    http://www.gmpartscenter.net/oe-gm/10153057
  10. #10 Re: Door panel clips
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    You can get these at most local auto stores too.
    Sent from my SM-P905V using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  11. #11 Re: Door panel clips
    you can, but they are much cheaper on line.
    i lucked out, bill sent me a box of old w body parts and stuff, and there was a bag of door clips in there, installed them asap lol
  12. #12 Re: Door panel clips
    Buffalo, NY
    Haha nice. I'll be buying the ones on amazon and just cutting them a little.
  13. #13 Re: Door panel clips
    GT Level Member mguzzo's Avatar
    Buffalo NY
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  14. #14 Re: Door panel clips
    Banned
    I would get the OE gm ones. They are expensive but they pull the panel up the tightest and dont break. I tried a few brands and thought they all sucked. Good luck
  15. #15 Re: Door panel clips
    GT Level Member atj8's Avatar
    Midwest
    not to thread jack but does anyone have some ideas to deal with all the plastic rattling ?
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  16. #16 Re: Door panel clips
    Dec 2014
    Maryland
    billboost says turn the radio up.
  17. #17 Re: Door panel clips
    Banned
    Quote Originally Posted by atj8 View Post
    Start by using the GM clips that I mentioned. While the panels are off use a soldering iron to touch up the plastic welds that hold the two plastic door panel pieces together. I hot glued more foam to my panels and also used dynamat. Take down your overhead counsel and do the same. Then start applying these ideas to the dash and center counsel. The dash has a bunch of screws that I am sure time has loosened. Once you get started you want to just keep going, but it is very time consuming.
  18. #18 Re: Door panel clips
    Buffalo, NY
    Just a little update. I ended up going with the pins I've linked below. They're much longer but fit just fine. I didn't bother cutting them at all. The doors are really solid now and there's no play in them. Wasn't hard at all to switch them out for all 4 doors. After just doing the doors there's much less plastic rattling sound. I didn't realize how much the doors alone were contributing to that.
    http://www.amazon.com/gp/product/B00...ilpage_o03_s00
  19. #19 Re: Door panel clips
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Bought those same ones awhile back. All the ones I replaced snapped. ALL the replacement ones. I won't buy them again. Good luck with yours.
  20. #20 Re: Door panel clips
    Buffalo, NY
    The new ones you bought snapped? All mine seemed good and I haven't had a problem opening and closing doors yet. The plastic didn't seem old when using them either.
  1. What type of door panel clips do i buy?
    By Pontiac Racer in forum Introductions/Noob Questions
    Last Post: 11-13-2014, 10:59 PM
  2. Door panel clips
    By green97 in forum General Tech Discussion
    Last Post: 06-24-2013, 09:36 AM
  3. Door Panel Clips?
    By ImColeTrickle in forum General Tech Discussion
    Last Post: 04-01-2013, 06:58 PM
  4. Door panel clips
    By Kopp in forum General Grand Prix Discussion
    Last Post: 07-22-2012, 04:27 PM
  5. What store can i find door panel clips at?
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2010, 07:54 PM
