Thread: Normal KR? Advice Needed!
Results 1 to 7 of 7
  1. #1 Normal KR? Advice Needed!
    Sep 2015
    Denver
    Have an 02 Gtp Around 120k on the dash. Just wondering if what my car is doing at my mod level is normal or not. Current mods that actually matter are 2.5Inch ZZP Dp,K&N Cold Air Intake,Iriduim AutoLights 104s. Have a 2.5ZZP Catback and ZZP wires and coils But i know those don't do much in terms of KR. Im on a 3.4 right now and seeing 2-3 KR Sometimes less. Have a 3.6 pulley too i usually run That i almost get little to no kr on. Just wondering If a Tune would help? I also Have some SD Headers I'm going to be putting on, hoping that helps too. Any Thoughts Are appreciated very much. Thanks!
  2. #2 Re: Normal KR? Advice Needed!
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    The headers should help a lot with that, a tune would probably help too. Either pulley up, or install the headers and tune. just my .02
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  3. #3 Re: Normal KR? Advice Needed!
    Kemmerer, Wyoming
    the headers should take away the kr, but you should also consider running copper tip spark plugs. iridium plugs are more prone to kr than copper
  4. #4 Re: Normal KR? Advice Needed!
    Sep 2015
    Denver
    Im thinking About Ordering a set of autolight 104 Coppers Actually. Whats the Recommended Gap For those? Thanks For the Quick Replies guys.
  5. #5 Re: Normal KR? Advice Needed!
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i would probably gap them .055" for that setup. stock is .060"
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  6. #6 Re: Normal KR? Advice Needed!
    Topeka, KS
    Pulley up, raise timing on tune for moar pwr. Then put headers on.
    Sent from my SCH-I545 using Tapatalk
  7. #7 Re: Normal KR? Advice Needed!
    Topeka, KS
    .55 on 104's
  1. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  2. Advice needed
    By psav in forum General Tech Discussion
    Last Post: 02-18-2011, 10:25 AM
  3. Advice needed
    By ksteb88 in forum Visual/Body Modifications
    Last Post: 07-29-2010, 10:04 PM
  4. advice needed
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-17-2010, 06:52 PM
  5. Hello all! Advice needed!
    By jeremylester in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 07:13 PM
