The buttons that control the map lights suddenly won't work. It's as if the circuit board that controls the buttons has come loose from the bezel, I.e. the buttons push and don't do anything. How do I remove the panel to check it out?
I think yours will be different, but here are some images of a non-sunroof light removed.....
http://chrisb.users.superford.org/Gr..._Lighting.html
Might help until somebody else posts up? 2 tabs at the rear of the housing hold it in place.
Alright I got the assembly out! The problem I'm having is both buttons stopped working, like they were free moving, not clicking to turn the lights on or off. Inside the unit are the two switch boxes and for some God awful reason they both decided to pop apart at the same time. Is there something that's supposed to hold the two halves together or do I just have to glue it and pray?
http://imgur.com/qumGtEI
