Thread: 04 gtp
Results 1 to 19 of 19
  1. #1 04 gtp
    Jul 2015
    ]Want to do some work on my 04 gtp trying to get over 300+hp would like to have some suggestions
    Sent from my SM-N920T using Tapatalk
  2. #2 Re: 04 gtp
    Crank horsepower or wheel horsepower?
    How much money you got in your pockets??
    Going over 300 to the ground is going to make your transmission fight for it's life if you abuse it. Or one sweet 3-1 downshift will snap the pencil strength input shaft in half.
  3. #3 Re: 04 gtp
    Jul 2015
    I would like 300 wheel I have some cash
  4. #4 Re: 04 gtp
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    e85 dude. and this question has been asked hundreds of times. Search.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: 04 gtp
    XP cam, headers, small pulley, custom tune with wideband, meth kit or E85 fuel, then hope the trans holds together.
  6. #6 Re: 04 gtp
    Jul 2015
    I bought it off a lot it has headers cold air intake 160 thermostat thicker plug wires
  7. #7 Re: 04 gtp
    Jul 2015
    Also has a 3.4 pully on it
  8. #8 Re: 04 gtp
    My post still says what you'll likely need. A different camshaft, more boost and more fuel or a different fuel.
    Lets break it down, factory is ~260hp crank ish or so, maybe. Then drivetrain loss you are at ~210-220ish, maybe. Your headers and intake might have gained you about 10hp if it's not knocking as bad anymore. But then that 3.4 might have increased the knock, just still added hp, thus maybe gaining you 20-30whp. To gain 80 wheel horse power is going to require more boost and better flowing internals.
  9. #9 Re: 04 gtp
    Jul 2015
    Ok
  10. #10 Re: 04 gtp
    Jul 2015
    Any suggestions on parts and where to get them
  11. #11 Re: 04 gtp
    I'll let you research that, broswer the vendor and read everything. Safety and monitoring the motor is key. Gotta pay to play.
  12. #12 Re: 04 gtp
    Jul 2015
    Ok thanks I guess
  13. #13 Re: 04 gtp
    Sometimes hard ball is the only way, learning and reading the only way to understand how it's all going to work. It's like school but on the internet with a bunch of dudes living in their parents basement.
    Fair warning, don't trust anything you read on the vendors website when they claim horsepower numbers or proper ways to mod a car or stage kits. They are all outdated and junk.
  14. #14 Re: 04 gtp
    Slower, Lower Delaware
    Got scanner?
  15. #15 Re: 04 gtp
    Jul 2015
    Scanner ?
  16. #16 Re: 04 gtp
    GXP Level Member
    Mar 2015
    Tomball
    We'll take that as a no.
    Order a BAFX OBD2 reader for $23 and buy the Torque Pro app for Android devices for $6.00, that will be the best $30 you will ever spend. If you have an Iphone like I have then but an android device like a cheap tablet from a pawnshop or something.
    Jeff
  17. #17 Re: 04 gtp
    Jul 2015
    Ok
  18. #18 Re: 04 gtp
    Yes you need to scan for Knock Retard (KR). Modifications may cause the engine to knock. The PCM will retard the timing to help but the engine may blow up. Things like a cam, rockers, and exhaust improvements will help reduce knock. Things like smaller pullies and increased timing may cause more knock. That is why you need to do the different things together while keeping an eye on knock.
  19. #19 Re: 04 gtp
    Jul 2015
    I see thank you
