Thread: 2005 Heater Inlet Hose
Results 1 to 4 of 4
  1. #1 2005 Heater Inlet Hose
    Jun 2012
    pa
    2005 3.8l.
    I am attempting a flush and fill of the cooling system, and need to install a tee in the heater inlet hose. (prestone flush and fill kit) Problem is, the 2 hoses from the heater core run in parallel to the block/pump. Which hose is which????? Thanks in advance........
  2. #2 Re: 2005 Heater Inlet Hose
    in the end it dont matter which one to tap into, it still flushes through the whole engine.
    or take both hoses off and fire it up, only one will push coolant out of it.
    best way to flush it to me is to remove the t stat, and then put the housing back on, leave the hose on the housing, take it off the upper rad. yank the lower hose to drain the engine and rad, then put it back on, then put a hose in the rad, fill it, then fire up the car, run it till clear water comes out of the upper hose. then take the hose out of the rad, run the car till no water comes out the upper hose, then shut the car, put the t stat back in and fill with one gallon of straight antifreeze, NOT the 50/50 stuff. and then top off with water, bleed the air. done.
    your cost, 15 bucks for new coolant. you 04 up guys dont even need a new gasket for the t stat most of the time.
  3. #3 Re: 2005 Heater Inlet Hose
    Naperville, IL
    You need more than a gallon of straight antifreeze. The 2005 GP has a cooling capacity of 11.2 qts. Adding only one gallon of 100% is a 35.7% mix. You need to add a min of 5.6 qts or a max of 7.8 qts to be in the 50-70% DexCool range.
  4. #4 Re: 2005 Heater Inlet Hose
    so less then 3 gallons? (what ive always figured) that mix if you read the bottle is good to -20. more then enough for most. but for those who see temps lower, should adjust as needed.
    and thanks for bumping a 2 year old thread.........
  1. Which one is heater inlet hose?
    By fuzzbutt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2013, 10:16 PM
  2. Replies: 11
    Last Post: 02-03-2013, 11:21 AM
  3. Heater inlet hose
    By PatrickMcL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 07:59 PM
  4. 2005 Grand Prix heater inlet hose?
    By xctment in forum General Tech Discussion
    Last Post: 01-17-2009, 08:43 PM
  5. location of heater inlet hose on 1994 grand prix?
    By bimple in forum General Tech Discussion
    Last Post: 01-01-2009, 06:37 PM
