Thread: power steering lines
Results 1 to 20 of 38
  1. #1 power steering lines
    Nov 2013
    bristol, tn
    I have high and low pressure power steering lines for 25 shipped, thanks.
  2. #2 Re: power steering lines
    GTX Level Member 94grandprix's Avatar
    Jul 2010
    Crandall, Georgia, United States
    Pm me
  3. #3 Re: power steering lines
    Jul 2010
    Is it 25 for both,do they have any wear on them?
  4. #4 Re: power steering lines
    Jul 2010
    Your messages are full
  5. #5 Re: power steering lines
    Jul 2010
    theres another one i need,it has the screw/bolt fittings on both ends and is skinnier than these ive got,its about half these sizes and is about a foot long,can you get it off and how much would it be also one side screws in near the drivers side area near the strut,thanks
  6. #6 Re: power steering lines
    Jul 2010
    UPDATE: ok I've had a few problems going on and couldn't work on my gtp, I started last night, I removed both little power steering lines that's on the rack and pinion, no holes, then realized there was a little straight pipe going from boot to boot on the rack and pinion, felt like drivers side was in but not passenger, how do I get it more secure in the boots, would pipe clamps work,I think this is my problem,have yall heard of this causing problems before?hears a pic of the line http://i1121.photobucket.com/albums/...psxqr75m7n.jpg
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  7. #7 Re: power steering lines
    Jul 2010
    It seems as if they just slide in the rubber boots
  8. #8 Re: power steering lines
    yup on the back side of the rack that metal tube just sits in the the boots on the inside connecting them together., theres a hole for the tube to live in. you may need a zip tie to hold the boot in place.
  9. #9 Re: power steering lines
    Jul 2010
    It flops a little so I thinking about buying some little pipe clamps and putting them on, all my fluid was coming out from the passenger side, at least I know the little ones aren't bad, the fat lines look ok and I got back up of them just in case
  10. #10 Re: power steering lines
    Jul 2010
    Scottydoggs does it have any sort of pressure on it?
  11. #11 Re: power steering lines
    if you had fluid leaking out of the boot thats the seal on the rack leaking. those boots are nothing more then a dust boot. that metal tube, the only purpose i cant see for it is to let air come out of the boot when it compresses to the other boot thats now stretching out.
  12. #12 Re: power steering lines
    Jul 2010
    It looked like fluid coming out of it, so fluid doesn't travel through that line? And with the boot I don't see any leaking out of it, there isn't to much to the power steering system so I'll track it down if that's not the problem
  13. #13 Re: power steering lines
    Jul 2010
    It has fluid running through it, I just blowed on the pipe and fluid came out
  14. #14 Re: power steering lines
    dont think theres supposed to be fluid in that thin line. see if its wet inside the boots, they should be dry.
    all mine did was connect to the dust boots.
  15. #15 Re: power steering lines
    Jul 2010
    I can't check it today, it's raining, but how could fluid end up there then, I thought some say if the boots rip fluid will come out then replace the r&p, I'm guess I'm going to put the clamps on it and put it all back together and fill it up and crank it and get under it and look
  16. #16 Re: power steering lines
    like i said, the boot is nothing more then a dust boot, its the end seals that leak. so if the boots are leaking the seal is leaking. if there fluid in the boot, then it can push fluid into that thin line that connects the 2 boots.
    i cant see any other way for fluid to get into that line.
  17. #17 Re: power steering lines
    Jul 2010
    I know it has me puzzled to, but the boots seem to be ok, I've got the line in the house with me, I stuck a napkin on the end and blew on it and I swear it came out, I still have the taste in my mouth
  18. #18 Re: power steering lines
    lol yuck.
    lets put it this way, my old rack just quit life, no leaks. the first used one got dropped off with 2 wet boots, i sent it back, told them to get me one with dry boots, next day a bone dry rack was delivered, (it still had fluid in it, they just cut the lines off it) its worked perfectly and the boots are still dry.
    so wet boots are no good.
  19. #19 Re: power steering lines
    Jul 2010
    I bet replacing the r&n is rough, idk if it's what I need then, with fluid in the car the steering performs great
  20. #20 Re: power steering lines
    park over cardboard at night, it will tell a story.
  1. Power Steering
    By RustyHO in forum General Tech Discussion
    Last Post: 04-01-2013, 05:55 PM
  2. Header hitting sway bar and power steering lines
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2011, 10:39 PM
  3. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  4. Power Steering
    By greengaels2 in forum General Tech Discussion
    Last Post: 12-29-2008, 01:45 PM
  5. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
