Thread: *Added* Shift Kit, 4th shaft, sprags, Oil pan, gaskets, Dogbones, & More!
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 100
  1. #41 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    TTT Finally available.. I can get you a new, just released Sonnax Billet 3rd piston kit. Drop in replacement with 50% more apply area = 200% more clamping force. Will work with stock or zpack or any other setup that works with the OE piston!!
  2. #42 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    TTT
  3. #43 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Money vortex synysterjoe's Avatar
    Mar 2013
    Columbus
    You said you have random trans parts? How much would you need for all the random torrington bearings?
  4. #44 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Lorain, OH
    Still have this stuff. any takers?
  5. #45 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Just saw ur comment im running a precision 6466 billet , dual ball bearing , .70 ar , S-cover ( 4" inlet , 2.5" outlet i believe ? )
  6. #46 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Indianapolis
    Your pm inbox is full. But I am curious how you modify an HVII to fit in an l26. And will I need longer bolts to install the HVII?
    2004 GT N/A: 343whp/240wtq, L26, HV3, headers, intake, shifting at 9k rpm, stock bottom end, tuned by me
  7. #47 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    TTT
  8. #48 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Jun 2013
    St.Louis
    are the poly mounts new or used?
  9. #49 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Lorain, OH
    Quote Originally Posted by BDAB View Post
    They are used. Bought them already in front mounts then I got the black friday WBS kit with all the mounts so I never ended up using them. They are in very good condition and come already installed in the mount bracket. LMK if you have any other questions or need pics
  10. #50 Re: 3k converter, Pushrods, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet
    Lorain, OH
    TTT
  11. #51 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    Weekend bump.. sold pushrods. Added red poly mounts
  12. #52 Re: 3k converter, L26 UIM, 4th shaft, sprags, poly mounts, Oil pan, Billet 3rd
    Lorain, OH
    TTT Sold mounts in brackets. Still have stuff left! Anyone?
  13. #53 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    TTT
  14. #54 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    weekend bump. sold trans filters and 4th shaft.. may have one of those left. looking now....
  15. #55 Re: 3k converter, 4th shaft, sprags, poly mounts, Oil pan, v/c gaskets, Dogbones
    Lorain, OH
    ttt
  16. #56 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    TTT
  17. #57 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    ttt
  18. #58 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Lorain, OH
    Once again.. weekend bump... anyone need some trans parts etc?
  19. #59 Re: 3k converter, Pushrods, L26 UIM, ARP Main Studs, Trans Parts, Oil pan, RTV, HV2..
    Oct 2012
    oakdale mn
    Quote Originally Posted by DJNight2k View Post
    how much for the sonnax?
  20. #60 Re: 3k converter, 4th shaft, sprags, poly mounts, Oil pan, v/c gaskets, Dogbones
    Lorain, OH
    Pretty much the same price as you can get it anywhere now. I had a place that had them in stock when they first came out so I posted that in case anyone else wanted to order with me. I would be buying it new, I don't have any preowned ones.
  1. Doing LIM and Valve Cover Gaskets
    By djimmy31 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2009, 07:08 PM
  2. Valve Cover Gaskets
    By fragrep in forum General Tech Discussion
    Last Post: 03-11-2009, 07:46 PM
