Thread: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,etc.
Results 1 to 15 of 15
  1. #1 Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,etc.
    Kemmerer, Wyoming
    Cleaning my garage out of all the spare stuff I have been hoarding, everything is plus shipping:
    Moog K6662 rear sway bar end link only one side 20 dollars
    engine mount that I filled with polyurethane 50 bucks
    Four stock length dogbones 30 bucks
    Cam key 2 dollars
    Snout fill plug 5 dollars
    Throttle body spacer 10 bucks
    Oil pan gasket 20 dollars
    L67 map sensor 20 dollars
    L32 map sensor 20 dollars
    L36/L26 map sensor (2) 20 dollars
    fuel pressure regulator 20 dollars
    northstar throttle body throttle position sensor (2) 20 dollars each
    L67 throttle position sensor 20 dollars
    fuel injector clips 5 dollars
    Parts located in Kemmerer, WY 83101
    offers accepted, PayPal preferred.
    https://drive.google.com/folderview?...2s&usp=sharing
    Sold:
    180* thermostat 10 bucks
    zzp poly trans mount, used 50 bucks
    intercooler fill adapter 10 bucks
    Hud dual gauge pod 20 dollars
    Off board pcm tuner with connections for 97-03 and 04+ made by billboost, 50 bucks
    Moog 80778 lower control arm bushings should be problem solver 10 bucks
    2 Monroe 902973 Strut-Mate Mounting Kit 40 bucks
  2. #2 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Jul 2016
    Florida
    Interested in the poly trans mount!
  3. #3 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    I'll do 55 shipped on the poly trans mount if sent as gift
  4. #4 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    bumb
  5. #5 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    Bump
  6. #6 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Nov 2011
    Bayamon, Puerto Rico, Puerto Rico
    The oil pan gasket is mine!
  7. #7 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    Quote Originally Posted by stonecold0469 View Post
    It will be if you pay for it
    I would imagine shipping will be expensive to Puerto Rico
  8. #8 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Nov 2011
    Same price as any state throughout usps.
  9. #9 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    pm me your address, and I'll get an estimate on shipping. it's not heavy, but the box is a bit large.
  10. #10 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    SE Level Member onklp's Avatar
    Apr 2016
    Canada
    This Strut-Mate Mounting Kit is for the rear shocks and can you send it to canadas ?
  11. #11 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    they are for the fronts only. shipping to Canada is expensive and would likely double the actual cost.
    Quote Originally Posted by onklp View Post
  12. #12 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    let me double check those strut mate mounting kits because I thought they were for the front's but it would seem I am wrong.
  13. #13 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Kemmerer, Wyoming
    thread updated with sold items
  14. #14 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    GT Level Member bachert24's Avatar
    Jan 2015
    Can I have a pic of the engine mount?
    Sent from my LGLS992 using Tapatalk
  15. #15 Re: Garage Cleanout. sensors, strut top plates, zzp pod gauge, oil pan gasket, Misc,e
    Jan 2015
    Nm
  1. Garage Cleanout
    By ls1camino in forum For Sale - Parts
    Last Post: 10-10-2013, 11:25 PM
