Thread: I just put engine in need help
Results 1 to 9 of 9
  1. #1 I just put engine in need help
    SE Level Member shooky's Avatar
    Mar 2013
    MICHIGAN grand rapids
    I try to start it just the selonoiond but it don't crank what am I doing wrong
  2. #2 Re: I just put engine in need help
    Need more info with complete sentences.
    What car, what motor??
    Double check all plug in, grounds, fuses etc etc..
    If the starter just clicks, then you have a grounding issue.
  3. #3 Re: I just put engine in need help
    Mar 2013
    Sorry it's a 99 gtp that was what I thinking I'll keep looking thanks
  4. #4 Re: I just put engine in need help
    Buffalo
    Lmao wtf is a selonoiond?
  5. #5 Re: I just put engine in need help
    Mar 2013
    It's my phone I swear lol Damm auto correct
  6. #6 Re: I just put engine in need help
    As long as you hooked up the ground and starter wires properly, then your battery is questionable. Check connections at the grounds, starter and then battery terminals
  7. #7 Re: I just put engine in need help
    Mar 2013
    Thanks I haven't had much time to get out and work on it I'm almost positive it's a ground issue
  8. #8 Re: I just put engine in need help
    Sounds like either your battery is dead or you wired up something wrong to me.
  9. #9 Re: I just put engine in need help
    Sep 2014
    Worcester, MA
    I assume the engine isn't seized?
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
