Thread: 3.8 Engine Noise
Results 1 to 4 of 4
  1. #1 3.8 Engine Noise
    Aug 2014
    Kansas
    I have a 2000 GTP with 185k miles. It has developed an engine noise that makes an "ERCH" sound about every 1.5 to 2 seconds at idle. the noise will speed up when the RPM is increased. The noise seams to be coming from somewhere around the #1 cylinder to the middle of the intake. I have taken off all of the belts and started the engine and it makes the same noise. I originally thought it would have something to do with the timing chain do the slower than RPM speed. If it was a bearing I think it would be a lot faster or continuous. Any help would be appreciated.
  2. #2 Re: 3.8 Engine Noise
    Take a video.
    It could be a rocker or a lifter going bad.
  3. #3 Re: 3.8 Engine Noise
    Aug 2014
    Kansas
    I currently have it disassembled down to the timing chain. There is no significant wear or slack in the chain.
  4. #4 Re: 3.8 Engine Noise
    Aug 2014
    Kansas
    Engine is back together. Attached is the you tube video of the car running without the belts on. http://youtu.be/DbV19x0nQ4I
  1. Noise from engine bay
    By Danomite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2014, 06:57 PM
  2. engine noise
    By carlover89 in forum General Tech Discussion
    Last Post: 01-04-2012, 03:31 PM
  3. Engine noise
    By gerhardt02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2011, 09:49 PM
  4. 06 GP L32 Engine noise
    By GeeBee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2009, 11:59 AM
  5. Engine noise help please.
    By mathd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-01-2008, 08:50 AM
