Thread: Spark plug gap
Results 1 to 16 of 16
  1. #1 Spark plug gap
    SE Level Member ryanm086's Avatar
    Apr 2014
    I have a 99 gtp with the following mods, 1.9 roller rockers ported and polished heads, ported and polished blower, 3.5 inch downpipe with cat delete, 3.1 undersize pulley, tune by ZZ performance for 93 octane with kr, its my first time changing the plugs with the mods, and I don't think stock would come gapped right any suggestions on how to tell what the gap should be?
  2. #2 Re: Spark plug gap
    Apr 2014
    http://shop.zzperformance.com/store/...ark-Plugs.aspx also these are the plugs I want to order but I've heard that you can't gap iridium plugs.
  3. #3 Spark plug gap
    Boosted loves copper plugs
    And no you can't gap iridium
    I vote Autolite 104s gapped at .50-55
    04 Comp G.
  4. #4 Re: Spark plug gap
    Apr 2012
    Bancroft. Ontario, Canada
    x2
    Mine are gapped at .60
  5. #5 Re: Spark plug gap
    Apr 2014
    Alright so its best to stay away from the iridium then?
  6. #6 Re: Spark plug gap
    Iridiums are fine if you don't want to change them to often as opposed to copper where you'll be changing them every 2-3 oil changes.
    04 Comp G.
  7. #7 Re: Spark plug gap
    Apr 2014
    So then, the iridium plugs come ready to run since you can't gap them?
  8. #8 Re: Spark plug gap
    Apr 2014
    Do you have similar mods?
    Sent from my SCH-I500 using Tapatalk 2
  9. #9 Re: Spark plug gap
    why not gap iridium? I do it all the time
  10. #10 Re: Spark plug gap
    Apr 2014
    Would you mind explaining your procedure to gap iridium plugs?
  11. #11 Re: Spark plug gap
    I use a spark plug gapper and gap them to specs
  12. #12 Re: Spark plug gap
    Apr 2014
    Ok, so just the same as regular, not trying to insult you, just thought there might be something special you had to do, either plug I choose the general consensus seems to be to run around a .50 gap for my setup right?
  13. #13 Re: Spark plug gap
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Just if you need to open the gap use pliers as not to damage the tip thing, .50 is what iv been told and seen
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  14. #14 Re: Spark plug gap
    I'm running my 104s at .055, .50 is kinda huge lol
  15. #15 Re: Spark plug gap
    I never touch the center of the plug when I gap them. No need to
  16. #16 Re: Spark plug gap
    Apr 2014
    I'll try them at .55 first then, look out mustangs I'm coming
  1. Spark plug for our L36?!
    By slimguns in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-27-2013, 09:11 AM
  2. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  3. Spark plug gap
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 01:55 AM
  4. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  5. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
