Thread: supercharged motor swap 04 impala to 04 grand prix
Results 1 to 10 of 10
  1. #1 supercharged motor swap 04 impala to 04 grand prix
    Aug 2011
    corning ca
    just wanting to know if anyone took a series II motor supercharged motor and made it work in a series III N/A car. my motor was messed up by the previous owner and i can get a supercharged motor from a 04 impala from the local junkyard here for real cheap. i know the supercharger is not electronic tb and the electronic tb one won't bolt up to the cable throttle. also the series II supercharger isn't as good but i need a motor and would like to upgrade. im having a hard time finding a whole series III motor that is supercharged for a decent price. also can i bolt a series III supercharger to the series II intake?
  2. #2 Re: supercharged motor swap 04 impala to 04 grand prix
    you cant do it, you'll need to get the pcm tuned, a Tb adapter, and maybe swap the alt and bracket maybe, if its not the same one.
  3. #3 Re: supercharged motor swap 04 impala to 04 grand prix
    Aug 2011
    corning ca
    so a gen V blower would mount to a series II intake or just the heads
  4. #4 Re: supercharged motor swap 04 impala to 04 grand prix
    Aug 2011
    corning ca
    does anyone sell an adaptor. i know about the pcm and i was hopeing the brackets would bolt up. basically use everything off the series III minus the supercharger related things
  5. #5 Re: supercharged motor swap 04 impala to 04 grand prix
    London Ont, Canada
    ive never seen a DBW TB adapter to Gen3
  6. #6 Re: supercharged motor swap 04 impala to 04 grand prix
    If you could find a gen v sc you'd be set.
  7. #7 Re: supercharged motor swap 04 impala to 04 grand prix
    You can put a gen v on a series 2 lim if you open it up a bit
  8. #8 Re: supercharged motor swap 04 impala to 04 grand prix
    Aug 2011
    corning ca
    so i can get the cheap series 2 supercharged motor and then find a gen V blower and lim and i would be set
  9. #9 Re: supercharged motor swap 04 impala to 04 grand prix
    yep it's that easy
  10. #10 Re: supercharged motor swap 04 impala to 04 grand prix
    Feb 2013
    Missouri
    Don't forget about a tune, and opening up the Series II LIM for the Gen V.
  1. swap a series 2 supercharged motor for a series 3 supercharged into my 2000 gtp
    By 2000GTPGUY in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2012, 04:26 PM
  2. 1997 Pontiac Grand Prix to Supercharged engine swap
    By 1997GSX in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-28-2010, 08:00 AM
  3. GTP 3800 Motor swap into 2001 Grand Prix SE 3.1 body
    By HomeBoyShopnClub in forum General Tech Discussion
    Last Post: 08-19-2009, 07:45 PM
  4. Motor Swap in 1997 Grand Prix GT Coupe L36
    By VGPGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-11-2009, 06:00 PM
