Thread: grand prix gtp intake leak/ x-mas lights across dash nightmare!
Results 1 to 4 of 4
  1. #1 grand prix gtp intake leak/ x-mas lights across dash nightmare!
    SE Level Member dbrown68's Avatar
    Aug 2011
    Marshall,Tx.
    I'm fishin for some input on this common 3.8 leaking intake/ pontiac issue..lets see..where to start..
    it all started with a catalyst code a couple years back, and my darling wife like most chose to ignore the problem so long as the wheels rolled under its own power..then this is when the gtp decides to side with me..so then we get bombarded with multiple warning indicators abs,TC,SS,steering etc, so I was google bound...did frnt hubs, and nothing, then brakes, nothing, then it started running rough and seems like the accellerator pedal gets harder to push, i did the intake, nothing, now it's shifting sluggish, I checked a few other things, egr,vac and fuel, batt,.....as if this wasn't enough, we also have an 01 firebird....guess what it's doin?
    well any suggestions?
  2. #2 Re: grand prix gtp intake leak/ x-mas lights across dash nightmare!
    scan the car and post the codes you have now.
  3. #3 Re: grand prix gtp intake leak/ x-mas lights across dash nightmare!
    Aug 2011
    Marshall,Tx.
    K the saga continues, egr checked out awhile back but earlier someone suggested that I try running it without it plugged in, and WOW..it was real close to running like it used to, but it was still shifting sluggish, then after awhile naturally the engine light is back, scanner showed three codes all related to the egr.pugged it back in, light goes out, no more codes, but runs like crap again!
  4. #4 Re: grand prix gtp intake leak/ x-mas lights across dash nightmare!
    Pull the egr off and clean it. Clean the tb and sensors too while you're at it
  1. 04 grand prix dash lights
    By Holcomb21 in forum Audio, Security & Visual Electronics
    Last Post: 08-23-2012, 11:30 AM
  2. Shifting Lights , AC Lights, Door Lights All Went Out?? Grand Prix 04
    By Levi Hardin in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2012, 12:49 AM
  3. Dash Lights out and Tail Lights out on Pontiac Grand Prix 2002
    By aaronman in forum General Grand Prix Discussion
    Last Post: 05-09-2012, 08:31 AM
  4. Replies: 0
    Last Post: 12-04-2011, 01:48 AM
