Thread: 2001 GTP misfiring and spewing smoke
Results 1 to 10 of 10
  1. #1 2001 GTP misfiring and spewing smoke
    Minot AFB
    Hey fellas,
    like the title says it started spweing smoke so I took it apart. I took the m90 off and this is what greeted me. I need some advice, what could this be? The supercharger gasket? Should I dig deeper and replace the LIM gaskets too? First time digging this deep so I'd be thankful for any help/pointers.
  2. #2 Re: 2001 GTP misfiring and spewing smoke
    yes, replace the LIM aswell.
    and make sure you clean up all that coolant good and wash it all away, and dump some down the vally to clean away and change the oil atleast twice to insure you dont get a bigger problem.
  3. #3 Re: 2001 GTP misfiring and spewing smoke
    Take the TB off the SC. Is the gasket messed up at the bottom? That's where the coolant does a u turn. If the SC is wet inside, that's what happened. Clean that up and fix the gasket.
    Was the SC to LIM gasket wet by the yellow rings? If so..change the SC to LIM gasket and be done. Either way..I'd pull the TB and clean it while it's off.
  4. #4 Re: 2001 GTP misfiring and spewing smoke
    or do what bill said.
    but if the lim has never been done, its not a bad time to do it.
  5. #5 Re: 2001 GTP misfiring and spewing smoke
    Ohio
    everything above the heads should be replaced
  6. #6 Re: 2001 GTP misfiring and spewing smoke
    I do agree that it looks like your LIM gaskets are black and should be done while you are only 12 bolts away.
  7. #7 Re: 2001 GTP misfiring and spewing smoke
    Minot AFB
    I dont know where my response went so here it goes again.
    Thank guys, but have you seen something exactly the same before. I am afraid that it might be head gaskets or a cracked head....what are your thoughts on that?
    Thanks
  8. #8 Re: 2001 GTP misfiring and spewing smoke
    Head gasket can't do that.
    Yes I have...hell...I've diagnosed this over the phone which is why I told you to check what I did.
    And keep in mind..that WILL NOT BE A HEAD GASKET. Ok, thanks.. lol
    I'd put money on it.
  9. #9 Re: 2001 GTP misfiring and spewing smoke
    Minot AFB
    Thanks Bill, off to work
    I'll check back in....
    Tom
  10. #10 Re: 2001 GTP misfiring and spewing smoke
    Tom..I often toss this out and would pay. If you find it's a head gasket.. I'll paypal ya $20. For some beers to help you feel better.
  1. Misfiring above 4k rpm
    By thatguy in forum General Tech Discussion
    Last Post: 01-28-2012, 11:15 AM
  2. Heater Spewing Exhaust Fumes
    By Michael Lomb in forum General Tech Discussion
    Last Post: 10-20-2009, 09:39 AM
  3. need help!! misfiring???
    By icolex1 in forum General Tech Discussion
    Last Post: 02-26-2009, 03:49 PM
  4. Misfiring?
    By hotshot in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2008, 09:33 PM
