Thread: Temp problems
Results 1 to 2 of 2
  1. #1 Temp problems
    Apr 2011
    Katy, TX
    am having problems with my 06 grand prix, the water pump was leaking so I replaced that, then the temp would still get a little hot so I had the thermostat replaced, now its still getting hot. Someone told me to change the coolant sensor. i found out there are 4, does anyone know where they are located and how to tell which one is out and if this is my problem?
  2. #2 Re: Temp problems
    did you bleed the air out of the cooling system???
  1. Outside temp not working
    By Fiero in forum General Tech Discussion
    Last Post: 01-24-2011, 10:49 PM
  2. Temp Issues
    By rildin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-02-2010, 10:09 AM
  3. Is my temp okay?
    By tracker1925 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 07:52 AM
  4. outside temp sensor
    By silvermistchick in forum General Tech Discussion
    Last Post: 06-16-2010, 09:25 PM
  5. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
