Thread: car misfires
Results 1 to 7 of 7
  1. #1 car misfires
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    after dropping to a 3.5 pulley with a tune i have been having the same issue with my car, it hesitates and misfires under boost, it happens just on cyl 6 so i thought it was the EGR so i did the EGR blockoff since it dumped into cyl 6. but its still happening, what should i check next. i have also checked the coil packs, plugs and wires.
  2. #2 Re: car misfires
    KR and timing.
    Did you get an actual tune or a pcm from somewhere?
    You running a 180* tstat and colder plugs?
  3. #3 Re: car misfires
    Nov 2009
    centereach, NY
    actual tune made 235 whp weather corrected 250 wtq (weather corrected) had him come with me i boosted, and the scanner said no knock, but was showing misfires, anyway from 6 to 60 at some times. and it was weird because at some points it hit 13 lbs of boost, which is 3 lbs over what the tune said it made.... and yeah im running 180 t stat and tr6s
  4. #4 Re: car misfires
    Houston
    Im gettin almost the same thing...Cylinder 5 and 6 misfires at idle only though. The 6 is at about 40 at idle and slight throttle. But moderate throttle and above I have 0 misfires
  5. #5 Re: car misfires
    Nov 2009
    centereach, NY
    that could be injectors maybe.
  6. #6 Re: car misfires
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    what are the numbers you're talking about, number of missfires? how would you check that, with a scanner?
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  7. #7 Re: car misfires
    Houston
    They are the number of misfires in a cylinder per minute. I have an aeroforce scan gauge so I can keep an eye on each cylinder. My cylinder 6 misfire is gone after replacing the blown out plug.
  1. multiple misfires
    By rsookar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2010, 04:18 PM
  2. misfires??
    By paulaxe in forum Engine
    Last Post: 11-23-2010, 04:09 PM
  3. misfires may be another issue
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 09-30-2009, 11:02 PM
  4. random misfires
    Last Post: 09-14-2009, 06:26 AM
  5. WOT misfires
    By gotboost3 in forum General Tech Discussion
    Last Post: 11-12-2008, 08:58 PM
