Thread: Ignition Coil and Spark Plug Wires
Results 1 to 6 of 6
  1. #1 Ignition Coil and Spark Plug Wires
    Jan 2018
    US
    I hear ppl say stock is better ac delco... And I hear ppl say "Just get zzp coils and 10.5 wires etc... I want to hear from experience players. Which one or is it just a cosmetic preference?
    PS, what's this deal about NGK Spark Plugs?
    Please feel me in. Thanks!
    Sent from my SM-N950U using Tapatalk
  2. #2 Re: Ignition Coil and Spark Plug Wires
    Stock coils and stock wires.
    Anything else is just spending extra money. Larger wires aren't going to make the spark any stronger or better if the coil pack itself and the entire ignition isn't shoving out more voltage.
    What deal about NGK plugs?
    You didn't really ask a question there. Sure you can use them and they work but I'd some people use them and other don't. Stock delco plugs if you want them to last 80-100k miles or cooper core plugs for really modded engines because they are much cheaper to get when you need a colder heat range plug.
  3. #3 Re: Ignition Coil and Spark Plug Wires
    Jan 2018
    US
    Thanks for chiming in!.. NGK is what everyone is talking about on these forums is why I asked. Just want to try to clear things up for my opinion is all.
  4. #4 Re: Ignition Coil and Spark Plug Wires
    NGK makes a good replacement plug and I agree about wires and coils..
    MSD coils were known to cause misfires as quickly as 6 months after being put on the car.
  5. #5 Re: Ignition Coil and Spark Plug Wires
    Jul 2010
    Coquitlam,BC,Canada
    OE is more than fine. On my first tune-up, I used Delco plugs and wires. The second time, I used Bosch plugs and MSD 8.5mm wires (wanted red wires) and two years later have yet to have any issues.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Ignition Coil and Spark Plug Wires
    You know what I ran when I did heads, cam, N*, Gen V, headers, IC, EWP etc etc?
    Stock coils.. and until I had to moosh the wires I had Delco's.. at that point I needed more insulation and went to PRJ's. Aka better than ZZP equivalents that didn't let you down.
  1. Ideas on How to Clean Coil connections/Spark Plug Wires
    By Panzer4 in forum General Tech Discussion
    Last Post: 10-19-2009, 11:30 PM
  2. spark plug wires
    By jaysongt85 in forum General Tech Discussion
    Last Post: 05-28-2009, 02:30 PM
