Thread: ? Combustion chamber damage with broken rod under boost?
Results 1 to 2 of 2
  1. #1 ? Combustion chamber damage with broken rod under boost?
    Jun 2012
    Cold Spring, MN
    So, long story short, I grenaded a rod in my top-swapped 02 MCSS at 72mph in first gear (thought I had put the shifter in 2nd when passing an erratic driver, with my TOG dp gasket blown out and radio cranked to drown out the exhaust drone).
    Anyhow, what are the chances the heads aren't damaged... they are L32 heads that were supposed to have been pocket ported when they were rebuilt.
    Just curious if anyone has ever broken a rod under boost (in my case, around 8-9#) and not had any compression chamber/valve damage to their heads?
  2. #2 Re: ? Combustion chamber damage with broken rod under boost?
    theres only one way to know, take the heads off it.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Plastic peice in combustion chamber :(
    By snj111795 in forum Introductions/Noob Questions
    Last Post: 08-05-2015, 10:05 PM
  3. Boost Bypass Valve is forcing boost at idle and reverse.
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2013, 09:37 PM
  4. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
