Thread: engine harness
Results 1 to 5 of 5
  1. #1 engine harness
    Mar 2013
    maryland
    Does any one now what needs to be done to run a sc wiring harness on a top swap in regards to the abs control module?
  2. #2 Re: engine harness
    you dont need a sc harness, you change a pig tail on the map sensor, and thats it really.
  3. #3 Re: engine harness
    Mar 2013
    maryland
    Thanks for the input SCOOTY. I do no this already(that i dont have to) and i do sincerely appreciate your response i am also thinking about dropping in a sc engine and i do have the sc harness i just know the there is a difference with the abs control module and want to game plan whats going to be needed. Would i just need to swap out the module. As far as the pcm goes just with concerning the module would there need to be reprogramming for the abs system?
  4. #4 Re: engine harness
    abs has nothing to do with the pcm.
    id use whats in your car already, its all the same really.
  5. #5 Re: engine harness
    Dec 2012
    troll land
  1. Need LS1 EFI engine harness
    By centuryclub in forum Canada
    Last Post: 01-19-2017, 12:47 PM
  2. Need help! Engine harness 97 GTP
    By Bradh77 in forum General Grand Prix Discussion
    Last Post: 06-10-2015, 05:18 AM
  3. Engine Harness
    By dbextreme in forum General Tech Discussion
    Last Post: 06-20-2012, 04:35 PM
  4. Engine Harness Replacement
    By grandprixgtcv3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2009, 01:04 AM
