Thread: No crank no start.
Results 1 to 20 of 20
  1. #1 No crank no start.
    Feb 2017
    Washington
    My Pontiac has no crank. I replaced the batterie, the starter, I tested the ignition switch, all the grounds to the engine. The TRS isn't bad. Everything works up to the flywheel. I know the engine is not seized I can manually rotate it. When try to turn it over the flywheel moves about a inch, everything stops and it moves back again.
    I am stumped on what's wrong with my vehical.
  2. #2 Re: No crank no start.
    Antioch, IL
    whip out the volt meter and check for power at the starter
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: No crank no start.
    Feb 2017
    Washington
    I already did, everything is good, it's reseving and sending the right amount of power
  4. #4 Re: No crank no start.
    Feb 2017
    Washington
    This is why I have no idea what's going on I have checked everything and everything is getting power and sending it.
  5. #5 Re: No crank no start.
    Antioch, IL
    does the solenoid click?
  6. #6 Re: No crank no start.
    Feb 2017
    Washington
    Yes it does
  7. #7 Re: No crank no start.
    if its a na engine i bet its hydro locked form a failed upper intake, take the spark plugs, out, then crank it. if it spins free and coolant shoots out, that is the time you ask your self just how many times did i try to start it and it was moving that inch and back, cause doing that over and over and over will kill the rod bearing.
  8. #8 Re: No crank no start.
    You are positive that no cylinders are filled with water/coolant and causing a hydrolock situation?
  9. #9 Re: No crank no start.
    Feb 2017
    Washington
    Okay thank you! I will try that tonight. And let you knows if it works
  10. #10 Re: No crank no start.
    Feb 2017
    Washington
    I didn't think of that I will be seeing if it's hydro locked. How does that happen?
    Before this I was also having a issuses with misfires
  11. #11 Re: No crank no start.
    Feb 2017
    Washington
    If I killed a rod bearing what do I do and how do I tell if I did?
  12. #12 Re: No crank no start.
    Quote Originally Posted by Undead auto View Post
    you get another engine if thats the case. rebuilding these dont always go well.
  13. #13 Re: No crank no start.
    http://www.grandprixforums.net/threa...36-UIM-Failure this is why it happens, most still have the plastic lim gaskets that can also fail, so you change then at the same time.
  14. #14 Re: No crank no start.
    If the motor is filled with coolant, try and drain a bunch out of the block then re-install the spark plugs. That way when you fire it up it won't fill with coolant again, if the motor starts knocking then it's toast. You can run it for several minutes with no coolant in it.
    If no knock, repair the engine as needed. Without knowing exactly what you drive, you likely need upper intake and lower intake gaskets if it's a 3800.
  15. #15 Re: No crank no start.
    Feb 2017
    Washington
    How did I fix a hydro lock? I have very recently been doing all the work to my cars myself and never have ran into something like this
  16. #16 Re: No crank no start.
    I said what needs to be replaced in my post above if it did hydro lock the motor. Sometimes even in the intake manifold needs replacement.
  17. #17 Re: No crank no start.
    Feb 2017
    Washington
    I drive a 1999 Pontiac 3800 cc 3.8 lt
  18. #18 Re: No crank no start.
    Feb 2017
    Washington
    OKay thank you!!!
  19. #19 Re: No crank no start.
    Feb 2017
    Washington
    It's not a hydro lock
  20. #20 Re: No crank no start.
    Then it still sound electrical if the starter won't keep spinning.
  1. Crank no start!
    By RobGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2014, 09:09 PM
  2. Crank but no start.. Help!
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 11:31 PM
  3. Crank but not start
    By Coldwaves in forum General Tech Discussion
    Last Post: 05-20-2013, 05:21 AM
  4. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
