Thread: Exhaust Headers
Results 1 to 20 of 37
  1. #1 Exhaust Headers
    Jul 2016
    Algonquin
    hi im looking for headers. and i want to know what everyone here thinks. i eventually plan on going down to a 3.1 pulley so what are my best options. ive herd everything from pace setter to speed daddy and even zzp. what are my best options. i kind of want speed daddy but herd they were junk and i kind of want zzp but its pricey. i have enough to buy the zzp but if speed daddy is just as good i mean why not.
  2. #2 Re: Exhaust Headers
    speed daddy work fine, 80% of us here run them.
    and you aint running a 3.1 pulley with out a load of other things first. a 3.4 is the wall till you add about a grand to your mod list.
  3. #3 Re: Exhaust Headers
    Jul 2016
    Algonquin
    i mean my full mod list will cost somthin like 8 or 10k
  4. #4 Re: Exhaust Headers
    Nov 2015
    WI
    Quote Originally Posted by That SlowPontiac View Post
    Was this a joke or are you really going to drop 10K on mods?
  5. #5 Re: Exhaust Headers
    Quote Originally Posted by GTPNovak View Post
    lol, $10k in a GP is the best way to spend money on an FBody or something else.
    That's just hysterical.
    I know because I've done it. Max laughs.
  6. #6 Re: Exhaust Headers
    Kemmerer, Wyoming
    I wonder if people even spent 10K in mod's on these things when they came out new. I'm sure most of the posters in this thread are well aware that a Camaro could be bought, money spent on mod's so it would run 10's, and cost a total of 10K
  7. #7 Re: Exhaust Headers
    Jul 2016
    Algonquin
    i know. i plan on doing an entire top swap and full bolt ons
  8. #8 Re: Exhaust Headers
    then you'll never ever ever ever, run that small pulley lol ask me how i know.
    if your plan is a top swap buy a tuner too. canned tunes suck on a top swap.
  9. #9 Re: Exhaust Headers
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    I plan on doing a 3.1 pulley, I also plan on having something to put that pulley on.
    GPONA #1 Cyber Bully
  10. #10 Re: Exhaust Headers
    im sitting here telling you cant always have what you want.
    im running a l36 bottom end, ported l67 heads, 1.95 yella terra roller rockers, a full size ic, ported lim, 42 lb injectors, sd headers. i own 5 pulleys, a 3.4, 3.2, 3,0, 2.8 and 2.6.
    ive can run any one i want, its just how much timing you willing to cut to run it, the 3.2 was at 13 degrees wot, it ran a 14.3 best run of 3 runs.
    now im on the 3.4 and 17º ish timing wot. off to the track soon to see if it breaks into the 13's.
    in the end, your never gonna run that 3.1 pulley. not with out it knocking and blowing up. why you need a tuner to mess with stuff to make it work.
  11. #11 Re: Exhaust Headers
    Kemmerer, Wyoming
    He could probably run a 3.0" pulley on a top swap with an xp cam and a full size intercooler, probably will also need some port work done on the heads and a good ported SC and lim. Better add at least 1000 dollars in parts if you want to run a 3.1
  12. #12 Re: Exhaust Headers
    ask bob, aka crazyguy03. hes a bottom swap, better ported heads, huge ass cam, ic 3.2 pulley and stock timing lol
    top swaps hate timing and boost, end of story.
    boost means jack shait too, the boost # is the restriction your measuring, not added hp.
    and im flowing rather well too if you ask me, 3.2 only had 9,5 psi of boost. the 3.4 8 psi. more boost is not a help.
    now the 3.4 on my l67 engine the car came with made 10 psi without the ic or ported heads, so you do the ricer flow math there lol
  13. #13 Re: Exhaust Headers
    only way i see you getting even close to a 3.1 is if you have e85 local. then you scrap the ic, buy a better fuel pump, a fp re wire, larger injectors and a tuner, cause you'll fing need it lol
  14. #14 Re: Exhaust Headers
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
  15. #15 Re: Exhaust Headers
    meet chip, hes an asshole who will be your new pal.
  16. #16 Re: Exhaust Headers
    Nov 2014
    BFE,Ohio
    And he don't care what you drive.
    Sent from my SPH-L710 using Tapatalk
  17. #17 Re: Exhaust Headers
    looks like chip and his brother chunk both showed up to the party lol
  18. #18 Re: Exhaust Headers
    Nov 2014
    BFE,Ohio
    and they brought friends
    5 of the 8 pistons let loose at same
  19. #19 Re: Exhaust Headers
    just what engine are we looking at here? and what did it take to cause that carnage?
  20. #20 Re: Exhaust Headers
    Nov 2014
    BFE,Ohio
    A Ford 351 Windsor that was stroked to 410 it let loose due ****ty qc by dss racing
    I had the motor built by them years ago
    I Paid 9500 for a long block it had a junk lifter when I received it they wouldn't do anything about. 2k miles later it spins a crank barring due to a block oil passage. So I had a local shop turn crank replace barings re used the rods and pistons about another 8k miles and that happened I run widebands, egt, and data logger on both banks and tune was good about half way down the Track the car started missing/ knocking shut off trailed it home after looking around online there quite a few people with dss pistons that had let loose who data logs were good as well
    Basically if a big name drag racer or a magazine they make sure that you get good parts
    On Corral forums about about 2 years after I bought the engine there ended up being nonstop horror stories about there engines from people who's have rods snap cranks bend and pistons let loose
    Corral got bought out now dss is a sporting vendor there and you ***** about them you get banned
  1. Headers Vs Exhaust Manifold
    By ledfo0t31 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2016, 01:58 PM
  2. best exhaust to go with sd headers
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 09-20-2012, 10:15 AM
  3. Where can I buy Headers and Exhaust?
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2012, 11:22 PM
