Re: FS: HID Conversion Kits, just $80 including lifetime warranty!!!***
Kilroy
Since I have just the single bulb for high and low beam, the DRL's use that bulb, but at something like only half brightness. So I gather I would need the warning canceller? How would this affect my DRLs? would it basically eliminate them, or still allow them to operate? I live in Canada, so I need DRLs.
You are correct by using the warning canceller you are canceling that signal for the high beam to fire at half power to form your DRLs. In the case of HIDs, since they do not have the ability to fire at half power the warning cancellers actually disables the function of the DRLs.
Let me know if you need anything else,
Michelle
Stretch15
do you offer any 55w ballasts? and do you have an 880 hid kit for foglights on a 99'? thanks
We only offer the 35w kits. With 55w kits the bulbs create an excessive amount of heat, which can lead to damage over prolonged use in many headlight and foglight housings.
Yes! Here is a link, just select the 880 size and color temperature: http://www.diodedynamics.com/store/i...all-sizes.html
Michelle
Re: FS: HID Conversion Kits, just $89 including lifetime warranty!!!***
your hylux ballasts would solve the issue of DRL's burning out the ballast and allowing full power? i have my DRL disabled at the time being is why i ask..
Couch
How did u disable DRL's on an 08
marines542
covered the solar sensor on the dash. (little black dome right in the middle close to the windshield) so im basically running like it's nighttime all the time.
O I just wish the lights wouldn't come on at all during the day
Couch
covered the solar panels sensor on the dash. (little black dome right in the middle close to the windshield) so im basically running like it's nighttime all the time.
Can you share some pics? I would love to cover solar sensor on the dash if it is worth
Question on your HID kit. I have the aftermarket headlights in my GP, which means that it has spots for both a single high beam, and a single low beam bulb. The Grand Prix comes wired for a single high / low beam bulb. Do you offer a HID kit that will allow me to run a separate high and low beam, both HIDs for my Grand Prix?
Re: FS: HID Conversion Kits, just $89! Lifetime warranty!!! BRIGHT!!
As long as you select the same size, they should fit just fine into your housings. You could do single-beam kits for those housings.
Nick C.
Paul J McCain
Nick C.
I understand and know I could simply run a bi-xenon bulb, and have Hid high and low in a single bulb, but I am wondering if there exists a Hid system that can take a Single bulb hi/lo system and turn it into a separate hi and lo hid system.
Right now I have Hids as low beam, and a separate hi beam bulb. However, going from hid lo to regular hi beam almost makes it look like I've turned my headlights off. I am looking for a Hid system with separate hi hid and lo hid bulbs, that will work in my single hi/lo beam system.
