With a devils own meth kit how often do you have to change/put in a new mix of alcohol/meth ? Does it last for a while without any maintanance ?
with running 100% methanol on a M5 nozzle (5 gal/hr) it took me over a month to even get remotely low on methanol. i drive like a child and i get into boost a lot. i had it set to start spraying at ~6-7 psi and peak at 11 psi when i was running a 3.2 and about 12 pounds of boost. i had a 1/2 gallon tank.
Usually for post people you can go threw 1.5 quart of fluid with each tank of gas. Really just depends on how you drive it.
