Thread: Remove waterspots
Results 1 to 7 of 7
  1. #1 Remove waterspots
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    The last time it rained, and i was driving the GTP I noticed the windows and windshield were covered in waterspots.
    I seem to remember that you can use a claybar, or a mild polish on the windshield.
  2. #2 Re: Remove waterspots
  3. #3 Re: Remove waterspots
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    At work, we use glass cleaner, steal wool, then some red work rags as towels to dry them, the flip it over to the dry side and buff out the streaks. Use some sort of water repellent like rain x on your windows.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  4. #4 Re: Remove waterspots
    Nov 2012
    Madison
    I hit mine with the DA and ultimate polish in spring. Then follow up with washes and meguiars quik wax to dry.
    In fall I'll use Collinite845 to help the snow and crap slide off better.
    I do all the glass this way.
  5. #5 Re: Remove waterspots
    GTP Level Member simbah's Avatar
    Lala land
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  6. #6 Re: Remove waterspots
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by 04lss View Post
    Is this just on the glass or on the paint as well?
    A clay bar may not remove water spots. It is a good idea to clay the glass to start as this is the least aggressive method. If they are not removed then move to a polish. On
    If the waterspots are on the paint and are etched into the paint a clay bar will not remove them. You need to use a polish and possibly a compound depending on what type of water spots you have.
    Quote Originally Posted by simbah View Post
    This works really well. Just be sure to read the directions on the bottle. It is not safe to use on paint. Only on glass. The dye in the product will stain your applicator a bluish green. I would pick this up if it is only on the glass.
  7. #7 Re: Remove waterspots
    I break stuff selliott's Avatar
    Kansas City
    Steel wool?
  1. Help! Removing waterspots from inside headlight?
    By Daven in forum Visual/Body Modifications
    Last Post: 04-27-2014, 11:57 AM
  2. Please remove
    By itsCOMPlicated in forum Wanted To Trade
    Last Post: 05-03-2013, 09:07 AM
  3. How to remove oil pan
    By CheeseWithMyWHINEplz in forum General Tech Discussion
    Last Post: 07-01-2009, 01:54 PM
  4. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
