Thread: How to tint headlights and taillights
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    I live here. DirtDog's Avatar
    Jun 2012
    How much tint u recommend? 50%
    Sent from my pager using Morse code. ... .. ... ....
  2. #22 Re: How to tint headlights and taillights
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    I took a good amount of time on the both sets that I did and they turned out good. I think if you take your time and do it right they will be fine. I used to work with a kid that got pulled over for his and asked how he tinted them and he said that he put on like 5 coats of VHT and did not wetsand or use clearcoats. They just looked like someone had taken a flat black spray paint to them. They had very poor output too. So don't do that. lol
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
    Jun 2012
    Would a normal tint shop do a good job? And how dark
  4. #24 Re: How to tint headlights and taillights
    Quote Originally Posted by marines542 View Post
    I cannot vouch for what you should do with the headlights but for the tails if you use VHT do a light coat and then a second coat and that should be plenty of VHT. Itll be enough to notice but it wont be overdone. I just followed a write-up on here about how to do it and I think it involved wetsanding between each coat and then applying multiple coats of clear and wetsanding I believe.
  5. #25 Re: How to tint headlights and taillights
    Not sure what a tint shop would do but they would probably work with you and get an idea of what you are going for.
  6. #26 Re: How to tint headlights and taillights
    Ohio
    as dark as you want...best way for them to be done is to mix a few drops of black paint in with a cup of clear..thats the best look.
    Jun 2012
    What kinda paint and clear? Wet sand in between?
  8. #28 Re: How to tint headlights and taillights
    Ohio
    Best bet is to order tint vinyl wrap.
    Headlight Tint
    I had them send me two samples of the light and dark tint. That would be the better way to do the lights. Easy to do as well!!
  9. #29 Re: How to tint headlights and taillights
    Ohio
    they mix it, not you. They will use a spray gun, so better to go to an actual body shop. Not a tint shop.
    Jun 2012
    Quote Originally Posted by 99PGPGT View Post
    OK that makes more since. Theres is a really good body shop I'll call em later and see. If not I may try the tint on that sight
  11. #31 Re: How to tint headlights and taillights
    You know what makes sense?
    Going to the correct site.
    Wheeeeeeeeeeeeeeeeee, F7
  12. #32 Re: How to tint headlights and taillights
    I live here. TLSheff's Avatar
    One of the best write-ups I have found. Good pictures, solid info, and says what products he used for the results. This is how I plan to do it when spring time comes.
    How To: Apply VHT Night-Shades Spray Tint - Chevrolet Colorado & GMC Canyon Forum
    Altho I will probably make my own full write-up so we don't have to link to other forums for the info lol.
    The Boss Iceman6669's Avatar
    Jun 2011
    I will not lie, my tails are pretty dark.
    But thank the heavens the GPs were blessed with a third brake light...
    How to tint headlights and taillights Attached Images
    2011 F-150 Yote powered
    Jun 2012
    I'm gonna have my headlights tinted professionally at a local body shop. But before I tint them I want to upgrade the lights with some good HID's. What's the best and easiest way to do this. And I don't have an oven to bake my headlights in.
  1. taking out headlights, corners, taillights
    By rambo33 in forum Visual/Body Modifications
    Last Post: 10-10-2009, 12:41 AM
  2. Tint Taillights?
    By sUpErClEaNbLaCkMaChInE in forum General Tech Discussion
    Last Post: 09-28-2008, 06:23 PM
  3. Headlights and taillights!
    By Kyle73044 in forum General Tech Discussion
    Last Post: 03-24-2008, 09:14 PM
