Hey guys its beginning to get warmer here in Schererville IN. So Today I bought some Turtle Wax w/Carnauba (Paste) and Liquid Ice Polish, 1500 WET/dry Grit sand paper, 2000 WET/Dry Grit Sand paper, 7inch Polisher and I have some Turtle Wax rubbing compound I have for minor scratches.
I am not really sure what order to work. Wax or Polish first?
I have a couple scuff marks and minor scratches that look like there just in the clear coat.
When do I use the Rubbing Compound?
Should I wash in between Wax/Polish and rubbing compound?
Should I use the 7inch polisher when waxing or polishing or both?
Ive been reading on how to use each item, but the other in which to use them is kinda throwing me off.
I have a couple rough spots on the lower part of the bumper that go down to the primer. There small chips and inside is just black. I figured I would just get some spray paint and use a toothpick to fill those in. Other than the correct paint, will I need to put clear coat over that?
Any Info is appreciated Thanks guys
P.S. anyone know the color code for the 04+ GP's that are Blue/Green Crystal?
