Thread: tree sap removal
Results 1 to 12 of 12
  1. #1 tree sap removal
    Nov 2009
    wausau
    ya so i clay bared and waxed my gp last week and over the week i must have parked under a tree or something and now there is sap all over my hood
    any suggestions as to the safest way to remove this crap?
  2. #2 Re: tree sap removal
    Clay bar it again man...it sucks but thats what I use.
  3. #3 Re: tree sap removal
    GTX Level Member cerick08GP's Avatar
    Well, the first thing I would try is WD-40. I haven’t had sap on my car for ages so I can’t say it will work for sure. Anyway, WD-40 is harmless and you probably have some lying around so why not try it.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  4. #4 Re: tree sap removal
    Have you ever got WD40 on your paint? Do you know how hard that stuff really is to get off...its like spraying tire shine on your fender.
  5. #5 Re: tree sap removal
    Apr 2009
    Wausau, Wisconsin
    Ahem, I waxed your car .
    Ill show you today...
  6. #6 Re: tree sap removal
    Donating Users blkgp2000's Avatar
    Nov 2008
    IL
    I had this problem last summer and i just used some alcohol mixed with water. It came right out.
    ASCD SD Ram Air Hood, SLP CAI Kit, A-Pillar Gauge Pod, Oil Pressure Gauge and Voltmeter from Autometer, GMPP F/R STB with Don Rome Brackets, GMPP F/R Sway Bars, UMI Trailing Arms
  7. #7 Re: tree sap removal
    SE Level Member Purple Plazma's Avatar
    Nov 2009
    Trevose,PA. (near Philly)
    I've used "GOO GONE" on customer's sap problems. This only works if the sap is still soft however. Won't harm paint, lots of other uses too. Sold at Lowes and maybe Walmart.
  8. #8 Re: tree sap removal
    GT Level Member yulaw335's Avatar
    Michigan
    there is a local store in my area called meijer's and in there automotive dept. they have tree sap/bug remover for around 5 dollars (auto zone has it too).
    if you spray it on and let it soak for a minute or two then rub it out it will be gone in a couple minutes.
    I use it alot as I park under a pine tree so I know where you coming from
  9. #9 Re: tree sap removal
    Nov 2009
    wausau
    i rewashed and then re clay bared it and worked good thanx
  10. #10 Re: tree sap removal
    Wausau, WI
    alcohol is the best and it is mixed with water so that it doesnt evaporate as fast. Never put anything oil based on your paint....ever.
  11. #11 Re: tree sap removal
    Nov 2009
    South Boston, MA
    I usually use denatured alcohol and it takes it rite off, without harming paint
  12. #12 Re: tree sap removal
    Donating Users
    South Deerfield, MA
    Another good trick to use on the really hard tree sap that is really difficult to get off is using a razor blade. It has to be really sharp and you cannot use it on any convex angles. This is an excellent way to ruin your paint with deep scratches if not done right. You have to hold the razor at a very low angle so that the sharpest edge of the razor is held just off the surface of the paint. Do not attempt this if you do not understand this last statement. You will seriously damage your paint. The thin residue left behind is much easier to clean up than the thick drop that you started with.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  1. The tree fitty origin!
    Last Post: 09-17-2009, 09:31 AM
  2. tranny removal Q
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:14 PM
  3. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  4. engine removal
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 11:23 PM
  5. whats the shade tree
    Last Post: 02-19-2008, 05:44 PM
