Thread: Engine Cleaner
Results 1 to 20 of 27
  1. #1 Engine Cleaner
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Need a safe way to clean the engine bay. Any suggestions? Show season soon and its horrible from winter months.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: Engine Cleaner
    TDCRacing
    Guest
    What are you trying to clean? Grease or some type of salt from the roads? Anyway what i always have done is just pressure wash it at the car wash. Never had any problems doing it this way.
  3. #3 Re: Engine Cleaner
    Feb 2008
    Nashville
    Theres all kinds dirt/grease/grime i need to get off of there. Should i cover anthing beside CAI? thinking maybe Alternator
  4. #4 Re: Engine Cleaner
    TDCRacing
    Guest
    I have not ever worried about any of that. FWIW this was my old combo before i went turbo.
    Kept this looking pretty clean. Sorry i don't have any closer up shots. And the oil pan gasket leak does not help much.
  5. #5 Re: Engine Cleaner
    SE Level Member Jackd90's Avatar
    Chicago
    Quote Originally Posted by TDCRacing View Post
    Wow... i could eat dinner off that engine.
    Open Cone Intake, 180° Tstat, Autolite 605 Coppers, Autolite 7mm wires (will upgrade soon), Muffler delete (headers soon)
  6. #6 Re: Engine Cleaner
    May 2008
    McHenry IL
    damn TDC NICEEEEE S/C
  7. #7 Re: Engine Cleaner
    TDCRacing
    Guest
    It's urlosin's now
  8. #8 Re: Engine Cleaner
    Jul 2008
    Poteau Oklahoma
    I started using purple power, just spray it on and 10-15 min later wash it off with a garden hose.
    I dont have any pics but it workes pretty good. and it gives you time/room to get everthing, even under your ride.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  9. #9 Re: Engine Cleaner
    Aug 2008
    Long Island, New York
    ive been wanting to do this, but im so nervous because back when i had my 92 camaro i tried cleaning the engine and it wouldnt start for about 4 hours... i was not a happy camper
  10. #10 Re: Engine Cleaner
    GTP Level Member dstout's Avatar
    ky
    I used greased lightning I think from Home Depot but, I did cover the alternator and the coil packs with foil and it started right up and it was pretty clean too. You might not have to cover those things but it sucks when the car will not start.
  11. #11 Re: Engine Cleaner
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    careful about the strong detergents like purple power and grease lighting. best and safest is simple green.
  12. #12 Re: Engine Cleaner
    ky
    You can dilute greased lightning if you don't want it so strong. I used it straight and it got rid of all the nasty winter crap......I did find mouse turds on top of the blower, it was a cold winter!!
  13. #13 Re: Engine Cleaner
    Feb 2008
    Nashville
    Lol I found those too. I think I ran it out when I cleaned the engine cause my wife found one INSIDE her SUV. Was the funniest thing ever. She went and bought 5 traps and killed the poor bastard lol.
  14. #14 Re: Engine Cleaner
    Apr 2009
    stockton ca
    I use enigine bright engine cleaner or just the heated pressure washer at school it heated to 200+ * so it works pretty good
    Becarefull with simple green I love the stuff but it doesnt like some metals very much..
    When i did my plugs after just getting my gtp the guy before me didnt know about Cleaning the enigine bay and it was thick and nasty I used a good 3 cans of brakekleen granted not the best sulution but it worked in a pinch
  15. #15 Re: Engine Cleaner
    TDCRacing
    Guest
    Thanks lol
  16. #16 Re: Engine Cleaner
    SE Level Member shawnz90's Avatar
    Kenosha
    heres mine it was a IL car bought it a few week's ago and it wasss so dirty i just bought engine bright from autozone went to the spray wash place sprayed the degreaser on shut my hood washed the car then opened the hood and washed the motor worked great then went over some spots with wd40 then windex still have a little bit to touch up.
  17. #17 Re: Engine Cleaner
    queens
    simple green! I don't have recent pics but I now cleaned up the wires and polished up my rails
  18. #18 Re: Engine Cleaner
    London Ont, Canada
    That IS clean... i gota get mine cleaned up, you said you used simply green?? got a link to a product info.
  19. #19 Re: Engine Cleaner
    GTP Level Member SuperSport's Avatar
    Michigan
    Simple Green is a general purpose degreaser that is biodegradeable. Just google it. I used it as well and it works great.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  20. #20 Re: Engine Cleaner
    GT Level Member GrandPrixGT00's Avatar
    New Jersey
    can some one take a pick and use photo shop to show me the areas that need to be covered im gonna be doing this tomm on my day off
  1. just when i thought it couldnt get any cleaner...
    By kyle99gtp in forum Visual/Body Modifications
    Last Post: 08-16-2008, 12:06 AM
  2. any ideas on stainless tip cleaner?
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 07-30-2008, 11:05 AM
