Thread: Gen V/Gen 3 Belt Wrap, Now Available!!
Results 1 to 19 of 19
  1. #1 Gen V/Gen 3 Belt Wrap, Now Available!!
    SE Level Member kygtp's Avatar
    Oct 2008
    Cincy
    You get everything that you see in the pic above, a Billet Alum, custom machined bar, Longer bolts to work with most all full size IC, 76mm Pulley with bolt and washer, a half twist Billet Alum strap with one hole for the Alt. bolt and a bolt and lock washer for the Strap. All bolt are stainless steel, so need to worry about rust!
    With this Belt Wrap, it is designed to allow room for your spark plug wires and your IC hoses as well. With this Kit on My car, I have noticed no slip, when I was getting slip in the top end. All Kits that I have sold so far, which is not many, All the guys are pleased with the results.
    Price is going to be $170 Plus shipping.
    If you do not need the pulley, then the Price will be $158, I will included the bolt and washer for you though. Let me know what you want.
    Paypal is scmdh@insightbb.com
    Disclaimer: This kit does require you to measure and cut the strap to length and drill a hole for the strap to attach to the bar. Everyones setup is a little different, so I figured that it would be easiest for everyone to cut and drill their own. I will send you DETAILED instructions on how to do this, with pics for you.
    Also, for all you Gen 3 Guys, this CAN work on your setup, but you need to grind/cut down the "rib" by the last bolt toward the snout, shown in this pic. The Bar sits right over that rib, the Gen Vs DO NOT have this rib. It will work and there are guys that have done this with no problem.
    If you have any questions, please feel free to e-mail me, or post up. Thanks for looking
  2. #2 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Moore, Oklahoma
    I have one, FTMFW! Awesome product, fast shipping, and great customer support. Here's mine installed...
    BUMP for a good product...
    Shawn W. Larsen
  3. #3 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Wichita, KS
    Looks good Shawn. One of the cleanest engine bays around for sure.
    Dude...remember Branson?
    Loose them plastic pulleys on your belt, both for the supercharger and the serpentine. Replacement metal ones FTW!
    ~F~
  4. #4 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Moore, Oklahoma
    Never had a problem with the plastic ones, run em for years although mine are newer for good maintence. Besides, i'm planning on runnning billet pullies in the future, although it ain't on the top of my list. No one sees my engine or could careless around here.
    The metal are nice but there are many cars running the plastic pullies too.
    Shawn W. Larsen
  5. #5 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Wichita, KS
    Not a matter of if...but when. Give it time, sad to say.
    ~F~
  6. #6 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    So how would we know if we have any belt slip?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  7. #7 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Moore, Oklahoma
    Metal can fail just like the plastic, both will lock up eventully. Its the least of my worries honestly. I have yet to have a problem. My 93 GP had 160,000 miles original ones without an issue. I'm pretty sure my Trailblazer has them too.
    As for belt slip... MAF numbers at WOT are a good source. Also, sometimes belt dust on the underside of your hood and coolant bottle will let ya know. I was getting a little bit myself. Most guys sub 3.0" start seeing these issues, especially guys with 2.6" and 2.7".
    Shawn W. Larsen
  8. #8 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Wichita, KS
    Quote Originally Posted by Iron Indian View Post
    The bearings will seize you mean. Yet to see an NON OEM replacement do this , but have seen OEM replacments do this after about 2 years of being replced by the dealer.
    Some are good for a long time, others will start to make noise, and thats your warning sign to replace them. When they seize...and your belt gets trashed...you will wind up with more problems than you want sometimes. Seen PS pump resv. sawed through, seen the SC belt take out the serpentine belt, and leave ya on the side of the road etc etc. Just not into plastic parts that make a difference on your cars drive ability and durability.
    Gates metal replacements FTW.
    I don't have to worry about plastic ones on my car anymore. I have something waaaaaaay cooler than any part store can or would carry.
    ~F~
  9. #9 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Bastard Reptile's Avatar
    Kansas City, MO
    I actually had a metal one start to go out on mine a few weeks back...had a sqeak sqeak squeak......replaced the belt, sprayed it with brake cleaner etc until I started checking pullies...and sure enough. 3 years and 30k miles put the stress on it.
    I've also had a plastic one fail....when they go, the belt will tend to kind of chew through that pulley, so it may not kill the belt immediately. Metal ones will eat one up pretty quickly.
    Bearings can fail in anything. I'm not so biased toward metal or plastic anymore.
  10. #10 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    I live here. UR LOSN's Avatar
    Rockford, IL
    that looks like an awesome product!!!!!
    thats also a lot of bling bling!!!!
  11. #11 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    exactly whats the point of this product?
    COMP G
  12. #12 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Oct 2008
    Cincy
    This wraps the belt around the SC pulley more so that you get rid of the belt slip. Most guys running a sub 3.0 pulley are seeing slip in the higher RPM, so this helps with it.
    One guy put on on his car and ended up have to go to a large pulley due to maxing out his MAF and getting KR. All of which he did not have before. So it does work, plus it looks nice ; )
  13. #13 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Oct 2008
    Cincy
    I thought I would bring this back from dead, since I still have about 15 or so kits still available. Send me a e-mail @ scmdh@insightbb.com or post up if you have any question.
    I have been running mine on my car ever since I first posted this in 08', and has done a great job with my belt slip.
    Thanks for looking!
  14. #14 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    utah
    Mmmmm thinkin...looks good
  15. #15 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Bunnell, FL
    price still the same?
    I'm a Sex Offender
  16. #16 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Oct 2008
    Cincy
    Quote Originally Posted by z3r0 View Post
    Yes it is, but on these last couple that I have left, I will do free shipping anywhere in the US.
  17. #17 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    GT Level Member chrishova's Avatar
    Norfolk, Virginia, United States
    Do you make brackets for other things, like getting a large case AD244 alt on my '97 Grand Prix?!?!?
  18. #18 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    Oct 2008
    Cincy
    Quote Originally Posted by chrishova View Post
    Sorry, but I do not.
  19. #19 Re: Gen V/Gen 3 Belt Wrap, Now Available!!
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    Do you happen to have 1 more of these available? Ready to buy if you do. Thanks
  1. PC Belt Wrap Kit finally on the car....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 10-20-2008, 10:11 PM
  2. Protective car wrap/film??
    By David99GTP in forum Off Topic Discussion
    Last Post: 08-04-2008, 07:09 AM
  3. Header wrap anybody ?
    Last Post: 06-26-2008, 06:29 PM
  4. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
  5. Intake & exhaust wrap?
    By maybe_memories in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2008, 05:12 PM
