i have the gray ground effects on the bottom of my car and it is starting to peel in small spots any one no how to fix this problem or ideas to make it look newer seems the crap they use to make this cars is not long lasting laurie
Without seeing exactly what your talking about and how big the spots are you may beable to touch up. Otherwise if the spots are to big to be touched up you may be forced to live with it or repainted.
thanks for replyin well it looks like the flim is comming off so it has like spots of tears from material im not sure i will have to take a close up pic and send it to ya im not sure if its paint or what that material is made off do you no this anwer thanks laurie
X3 on monteman. My old camaro was doing that, fortunately it is easier to get trim for an 89 camaro so I bought from a bone yard.$25 over several hundred
Are you talking about the highsport package, mind was painted on, its paint code is FM8132 and clear, plastic-kota touchup brand, this was the only one i could find to match without going to a body shop., Since then have went all black
not sure :/ sorry
www.gmpartsdirect.com
i have the front and rear pieces and they are silver. the front have little tear but body shop should be able to fix it.
