Hi, there is this impala for sale with a police package on it do you guys know if those are fast.
What year is it? If it's between 00 and 05 then it's the same thing as a Grand Prix GT. Naturally aspirated 3800 (L36) with the 4T65E (non-HD) and 3.29 gears.
The only things about police cruiser Impalas (aka a 9C1) that are better than average is the suspension. Heavier duty trailing arms and sway bars. But, it's nothing particularly spectacular as the same equipment was available on the 04-05 Impala SS.
04-05 SS is the way to goUnless you go the top-swap route.
oh and no top speed limiter at 118mph like the GT.
dont forget you can turn the lights off while the car is running
sweet it is an 04, so from what you guys are saying, the impala should kick but. thanks :]
We've been over it time and time again on NAIOA. The 9C1's do not have the HD trans, and we're not sure where this myth started. You can look at the RPO list for any 9C1 and you will not see the RPO for the 4T65E-HD. You will, however, find the RPO code for the 4T65E (non-HD) with 3.29 gears. Prove it to yourself. Look up the part number for the non-HD passenger axle and then look up the part number for the 9C1's passenger axle. You'll see that the 9C1 calls for the non-HD axle.
This has been verified by 9C1 owners who have removed their transmissions and they do not have an HD. Power steering cooler? No. Oil cooler? No. The only additional cooler is the external tranny cooler. Computer work? No. Bin file is the same as that found in a 00-03 Monte SS (L36 with non-HD 3.29 tranny). Fan settings are the same...
Not sure where people come up with this stuff. The bulk of the modifications to a 9C1 is in the suspension department to take curb hopping and improve handling. The tranny cooler was added because 9C1s usually end up being heavier with all the extra police equipment.
See here for details on the tranny:
North American Impala Owners Association - 2000-2005 Engine, Exhaust and Transmission - Cop Car HD Tranny Theory - FALSE
Okay. A forum of thousands of Impala owners with hundreds of 9C1s and we don't know what they're equipped with. Feel free to message or e-mail any 9C1 owner on there about their car and what it does and doesn't have.
Here. Proof:
2003 Grand Prix GT axle part number is 661250
http://www.rockauto.com/catalog/rafr...&parttype=2288
2003 Impala 9C1 axle part number is 661250
2003 Grand Prix GTP axle part number is 661256
So, it has the same part number as the non-HD axle, and is distinctly different than the HD axle. So how does it have an HD? Go pop the trunk on one and look at the RPOs.
Oooh. Better yet, show me a 9C1 RPO sticker (take the picture). You will not see a sticker that says "9C1" (police package RPO) and "MN7" (HD trans). In fact, the original poster can look at the RPO before he buys the car. If it says "M15" it has the non-HD.
Edit: And I will stand corrected on part of it. An oil cooler and PS cooler were an option but not standard with the 9C1 package. Most don't have them but depending on the department that ordered the cruiser it can have it. My mistake.
Despite that, they don't have the HD trans. Here is the portion of the 9C1 brochure from Chevy covering the power train. Note, it says MXO (the letter "O") which is the non-HD trans. MX0 (the number "0") is the HD.
WOW, Really!!!...I will reference the 04 model since that it what the OP said he is looking at:
2004 Chevrolet Impala Police
PAGE one of that PDF:
MODEL LINEUP
ENGINE TRANSMISSION
3800 3.8L V-6 Heavy-Duty 4T65E 4-speed automatic
Impala Police Package s sAvailable in either police package (9C1) or undercover police package (9C3), Impala is powered by the proven
3800 3.8L V-6 engine that features a top speed fuel cutoff of 129 mph (208 km/h). To ensure continued running
at high speeds, Impala features an engine-oil cooler and a transaxle-oil cooler as standard equipment.
"At crime or accident scenes, police vehicles support emergency equipment, causing the battery to run down.
We've greatly minimized this situation by equipping the Impala police vehicles with a 125-amp alternator that
generates 96 amps at idle. That's the highest-rated idle output in the industry," Wiley added.To ensure continued running
at high speeds, Impala features an engine-oil cooler and a transaxle-oil cooler as standard equipment....not sure but thinking that qualifies as custom programming (and yes I know I did NOT specifically nor did anyone else specifically mention the braking system)The Impala police package also exceeds in the critical area of braking, with shorter 60-0 mph (97-0 km/h)
stopping distances than comparable Ford or DaimlerChrysler models, according to September 2002 Michigan
State Police testing. Credit belongs to Impala's four-wheel ABS with police calibration and heavy-duty front
brake pads
It features reinforced front struts, a reinforced aluminum engine cradle, and heavy-duty front
and rear stabilizer bars. Impala's police package is equipped with heavy-duty 16-inch steel wheels shod with
P225/60R16 H-rated tires.and even though its NOT listed...I can attest we have several 9C1 police vehicles that DO have adjusted fan turn on temps, Idle RPM's under load, Skip Shift trans settings etc (and No I did NOT put any of that on with my PT.) I can also attest that even though its not listed on rock auto...the radiator IS LARGER than the standard impala radiator...its the same size as ZZP's "Oversized" radiator....they also have different cooling fans:To help protect occupants in the event of an accident and against intrusion in the event of vandalism, the
Impala police vehicle is available with shatter-resistant laminated enhanced protective glass.
Seriously dude, a 9C1 Police package car is NOTHING like a standard car...there is a lot of additional safety and security stuff put on them as well as the H.D. upgrades....I have a degree in Mechanics and am a Cop who drives 04-08 Impala 9C1 packaged patrol cars every day I work...and I have been driving impala police package cars since 2000-2001 time frame...I think i know what they do and don't have.
and I will stand corrected, I was unaware they cut out at 129mph...or at least they are suppose too...I haven't had any but an old 01 model cut out like that...I assumed they removed it after that year...but from the brochure I can't say they did...it may just be a case of say one thing on paper to CYA themselves and remove it to make departments happy...the 129 was put there because that was the max rating for the tires they came with.
To the OP, if the 9C1 your looking at has been taken care of and maintained well, it will give you years of trouble free service...bottom line is like any car, check it out, test drive it, if your not mechanically trained etc...take it to a mechanic and have a full inspection of it done...if it passes and its a good price...GO FOR IT (obviously only if you want to of course).
Oh and here is the PDF on the current Police Impala:
http://www.gmfleet.com/pdf/Impala.pdf
sweet thanks man.
It is not an HD, despite what that pamphlet says in the wording. The key is the RPO codes. From the guy who knows more about Impalas than GM:
He owns NAIOA, and here is his profile. I dare you to contact him and ask about the HD. RPO codes must lie.Originally Posted by bbengineer
North American Impala Owners Association - Forums
Plus why has every tranny that has come out of a 9C1 been a non-HD? Why do the RPO codes say it isn't an HD? Also the fact that GM never made a 3.29 geared HD tranny and say so in their own SI manual.
And more advice, which if the OP wants a 9C1 he can go right ahead:
I'm still waiting on the picture of a 9C1 RPO sticker that says it has an HD tranny. Jeff, you work with them so it wouldn't take ten seconds to pop the trunk and look at the sticker to see for yourself. I already proved it takes the non-HD axle. We went through all of this a long time ago when people were buying 9C1 engine and tranny combos and coming away burned because they just bought a non-HD tranny.Originally Posted by bbengineer
I am done talking to a brick wall, obviously you could care less when its straight from the manufacturer....enjoy your ignorance.
And you enjoy yours. I've seen the SPID labels that list the non-HD tranny and I've seen the non-HD come out of a 9C1. Snap one when you're at work and we can settle it. If it has a HD RPO code and 9C1 on the same SPID label I will gladly eat my own words, my hat, or whatever.
I offer this final piece of evidence to show why I believe what I do. I procured a 9C1 SPID label myself. You can see I highlighted 9C1 and the tranny RPO M15.
I then looked up the build info for trannies under the RPO of M15. Here is the info GM provides. I highlighted the column for 9C1.
Note that the final drive and output shaft are of the STD (non-HD) variety. If they were HD, then it would say HD in those rows. You would find the M15 code on any car with a non-HD transmission. Any 98-03 GP GT owner can show that just by finding that code on their own SPID. The code for a HD transmission is MN7, which any member with a GTP can see by looking on their SPD.
Just to show what the RPO for a HD transmission looks like, we'll look up MN7 (which you GTP guys have):
Note that for the differential it lists it now as an HD, and the output shaft is also listed as the LONG type. Just like we know for the HD trans. Yet, it doesn't list those for the M15 build code found on 9C1s.
I have shown that I'm neither crazy nor stupid. The 9C1s do not have an HD trans. If someone can produce a SPID that says 9C1 and MN7, feel free. Otherwise that's all I can do short of pulling a transmission out of a 9C1 and take pictures while I do.
