Thread: Impala owners check in
Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 169
  1. #61
    SE Level Member 04DetroitLS's Avatar
    Detroit, MI/Lakeshore, ON
    Hmm broke tranny, is that from the one wheeled burnout in the picture. j/k
    They're both spinning look again
    and no its from 60k mile of me beating the piss out of her I'm pretty rogh on her, but she's held up pretty good so far, I think its either the diff or the input shaft that gave out. The donor car had 120k+ on her (for the hd upgrade), but a fresh tranny is on its way to get me thru till tax time, then I'll be sending the grenaded one to Trannyman for a real HD build
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by 04DetroitLS View Post
    Good choice on Trannyman. He did my cam and gears a few months ago.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #63 Re: Impala owners check in
    SE Level Member 05impalaSS's Avatar
    I figure ill chime in here ..been a while
  4. #64 Re: Impala owners check in
    Barksdale AFB, LA
    Welcome!
    What fuel rails are those, BTW?
    2009 Subaru Impreza WRX STI
  5. #65 Re: Impala owners check in
    Quote Originally Posted by Sabrewings View Post
    Welcome!
    PRJ
  6. #66 Re: Impala owners check in
    anyone get their imp to the track yet for some new times?
  7. #67 Re: Impala owners check in
    Barksdale AFB, LA
    I used my Aeroforce last night. That count?
    WizAired, ZZP 2.5" DP, custom catback, street tires, stock tune.
    Probably not 100% accurate, but it made me feel good when I was done.
  8. #68 Re: Impala owners check in
    SE Level Member jims05ss's Avatar
    I'm looking forward to getting back to the local track (Edgewater) now that I have just had Paul of PRJ help me install my SSIC and dropped down to a 3.25 pulley with a tune update! Hopefully, it'll get me into the low 13's, down from my best of 13.89 last fall.
    05 Impala SS; 13.84 @ 100. SSIC, 3.25 pulley, 1.9's, PRJ tuned PCM, ZZP SS P-log, ZZP SS 3" DP, ZZP TB spacer, 4" FWI w/9" K&N, U-bend & resonator delete, Magnaflow cat, wrapped crossover, 180 t-stat, PRJ Wires, 103's, Royal Purple, Eibachs, front & rear STB's, Aeroforce.
  9. #69 Re: Impala owners check in
    IIRC my PB was a 13.8 @ 104??? Yeah i know. sick for my mods....i have to work on my 60'.....but when i return from Korea, im going to get the oil leak fixed ....P&P blower, N*TB, ZZP tune and run a 2.6 with as much timing as I can.....Safetly..call it that...i may try to run a little 75 shot ..depends on how fiesty i get...my goal is to run a mid -low 12 without juice
  10. #70 Re: Impala owners check in
    Just out of curiosity, what mods did you hace when you pulled the 13.8?
    Sabre, next time you hit the track, let us know how accurate that thing is
  11. #71 Re: Impala owners check in
    ZZP 2.9" MPS, XP Cam, ZZP 1.6, 105#, Rollmaster Timing set, Lee flex plate, 3250 TC, ZZP Input Shaft, SLP headers, SLP exhaust, ZZP S2IC, Lucas 42.5#, PRJ Fuel Rails
    let the bashing begin
    Demodded---Done with the W-body scene
  12. #72 Re: Impala owners check in
    Holy crap, 05, what was your 60' on that 13.8 run? With those sweet mods I would think your car would be good for mid-12's already!
  13. #73 Re: Impala owners check in
    like a 2.1-2.2. I forgot its been over a year...
  14. #74 Re: Impala owners check in
    Hmm, that's not super bad. Still, with your mods your 1/4 should be ALOT quicker; were you running it at kind of a high elevation track? Was it super hot that day? Did you spin the tires alot at launch?
  15. #75 Re: Impala owners check in
    Yeah being in Tampa with 85+ degree weather and the humidity is always around 70% it sux. When i drove my car to PA b4 i came to Korea it was a different animal
  16. #76 Re: Impala owners check in
    Yeah, with those mods, get the car to a track at low altitude (well, Tampa has that, but...) with low humidity and cool ambient temp and I think you'd be amazed how much quicker it would run.
  17. #77 Re: Impala owners check in
    yes ..ZZP will be seeing me when i return next year...along with some nice welds and Hoosier QTP..my goal is a mid well LOW 12
  18. #78 Re: Impala owners check in
    i was gonna say, you sure the cam isnt installed 180* off? lol
  19. #79 Re: Impala owners check in
    Thats a good question...I was thinking about that a while ago. There is no way I can tell, i didnt do the cam install.
  20. #80 Re: Impala owners check in
    just wondering... something has to be going on, im usually all over the 13.7-13.9 range w/ 1.9-2.0 60's (cablemod FTW!) only difference, not cooled, and a 3.4, stock inj/heads/blower w/ +100k on them and im s1x not xp
