Hi everyone. I have gone through my detailing supplies and I have a few items that I have no use for. I would rather see these put to good use by someone. I will ship these within the 48 states. I do take paypal. PM me if you want to buy something. I am located in Lawndale, CA (90260)
Swirlx - Used once. Has about 13-14 ounces. $8 shipped
Description:
Meguiars Swirl X Swirl Remover is a non-abrasive paint cleaner and polish that removes the most common problem plaguing paint today – SWIRLS! Apply Meguiars Swirl X Swirl Remover by hand or with a dual action polisher to instantly remove swirl marks and restore crystal clear reflections to automotive paint. Meguiars Swirl X Swirl Remover makes it easy to restore a show car perfect shine!
Meguiars Swirl X Swirl Remover is an ideal product for anyone whose vehicle is suffering from micro-fine swirls. It requires no special equipment – just apply by hand to rid your vehicle of unsightly swirls and restore a smooth, reflective finish. The nonabrasive formula will not contribute to new swirls as it smoothes away micro-fine spiderwebs. Meguiars Swirl X Swirl Remover is designed to give you quick, dependable results by hand or DA polisher.
Meguiars Swirl X Swirl Remover cleans and brightens the paint to remove swirls without scratching, which results in a smoother finish. Meguiars Swirl X Swirl Remover is a step above Mirror Glaze #83 Dual Action Cleaner/ Polish in terms of polishing ability. Use it to remove mild to moderate swirls and holograms from all types of paint.
Meguiars Swirl X Swirl Remover straddles the line between Meguiar’s consumer products and their legendary professional line to give you wonderful results in the most user-friendly formula. Wipe on Meguiars Swirl X Swirl Remover with a soft microfiber cloth or applicator pad using moderate pressure. Wipe off with a clean cloth and then buff. To apply with a dual action polisher, use a polishing pad to apply a thin coat. Then buff with a microfiber towel.
Follow Meguiars Swirl X Swirl Remover with Meguiars NXT Tech Generation Tech Wax 2.0 for strong polymer protection and an eye-catching shine.
If swirls and holograms are hiding your vehicle’s perfect shine, use Meguiars Swirl X Swirl Remover to restore crystal clear reflections to any type of paint.
Colorx - Used once. Has about 13-14 ounces. $10 shipped
Description:
Revive, polish and protect with one quality product! A single-step prescription for alleviating dull, oxidized, and lifeless paint and creating explosive color! At the same time, you’re giving your vehicle enduring protection against UV rays, acid rain, salt, airborne pollutants, and brake and rail dust. Experts would advise a system of polishing (one product=one hour or more), then protecting (another product, depending on which one=at least ½ an hour) for proper, complete car care. Time consuming, money consuming, and unnecessary! Meguiar’s solved the problem with ColorX—a polish/wax combination that blows away the theory that you must do this in a two-step process!
Professionals and beginners experience fantastic results in a fraction of the time. The outcome speaks for itself! A heavy, deep color that looks like rich, wet paint and long-lasting protection.
Polishing is the step that purifies or exfoliates the paint to prepare it to be sealed in with a protectant. This is somewhat of an enthusiast’s or professional’s step, as many car owners elect to skip over it. Without polishing, you are locking in any pollutants, oxidation, water spots, scratches, swirls and contaminants that are left behind from a wash. ColorX allows you to go from wash to wax, skipping the middleman (polish), because now polishing/protecting can be accomplished simultaneously! Fine scratches and swirls are gone! Oxidation disappears! Color is restored! Vivid, dramatic color!
ColorX is safe to use on all painted surfaces, but please avoid vinyl and rubber. Use it for spot fixes, or treat the entire automobile. For best results, use out of direct sunlight. Apply a small amount of ColorX to a foam applicator. Spread in a thin even coat over entire vehicle and allow to dry. Buff away with a clean dry towel. Save time, money and elbow grease!
ScratchX 2.0. Brand new. Never used. $8 shipped
Description:
Meguiars SCRATCH X 2.0 is the must-have scratch remover for isolated paint blemishes! Only Meguiars SCRATCH X works by hand on all types of paint and all types of scratches. Micro abrasives remove scratches, rather than hiding them. Meguiars SCRATCH X 2.0 is a permanent solution to isolated paint scratches!
SCRATCH X 2.0 does more than just fill in and mask the problem; it’s a powerful polish that actually buffs the offending blemish away--without causing harm to your paint. Now, common sense will tell you that if a scratch is especially deep, or the paint has been chipped you need more than a polish. If you’re faced with such a daunting imperfection, seek the advice of a professional. Chances are you will require a machine applied pro-formula, and unless you’ve acquired some expertise with these items, you’re best leaving it to a professional. However, if what you are experiencing is a ‘surface’ blemish--SCRATCH X 2.0 will do the trick.
SCRATCH X 2.0 removes oxidation, blemishes, light stains, and surface contaminants. Perfect for a specific trouble area, or on the entire car. The strong yet gentle formula is safe for all paints and, unlike some surface correctors, SCRATCH X 2.0 will not abrade your paint--leaving more scratches than you began with. This formula is easy to use, and although it is widely acknowledged by collectors and enthusiasts as a “must have” product, even a novice detailer can use it with confidence.
Use SCRATCH X 2.0 and buff the damaged area, allow to dry, and wipe off the film to reveal a deep, polished shine. If applying SCRATCHX 2.0 to your entire car, remember to work one section at a time. Now that you’ve found the solution--apply it!
Hot Shine Tire Foam - 2 cans. Brand new and never used. - $6 shipped each. Will do 2 for $10.
Description:
Meguiars Hot Shine Tire Foam
Now in a foam formula, your tires will look even hotter!
Meguiars has made their Hot Shine Tire Spray even hotter by offering it in a foam formula. The foam spray clings and penetrates the rubber to create a glossy, black sheen. The foam technology lifts and releases dirt and grease so tires look clean and well-maintained.
Meguiar’s Hot Shine Tire Foam uses water-resistant polymers, combined with anti-ozonant technology (UV inhibitors) to arrive at a formula that lasts for weeks. Through rains and washings, Hot Shine hangs on and keeps your tires looking black and glossy.
The foam formula makes application a breeze. The foam breaks clear on the tire surface with no milky mess. You can literally spray and walk away. Meguiars Hot Shine Tire Foam requires no wiping, though it’s a good idea if you plan to drive the vehicle immediately.
Always work on cool clean tires. Spray on the shine and walk away. The foam formula penetrates, rejuvenates, nourishes and conditions the rubber, giving an unmistakable high gloss, wet-looking surface that says “pampered.” The glow nicely complements any vehicle.
Control the level of shine by adding another layer, or buffing off excess Hot Shine for a more subtle glow. Excess product should be wiped away anyhow, to avoid sling-off.
