Thread: In gear won't move
Results 1 to 5 of 5
  1. #1 In gear won't move
    New York
    So I've encountered another issue with my beloved GTP. I went to pick my son up from preschool today. Went back out for him and I in the car n when I lit it in drive I moved about a foot, then nothing, I put it in reverse nothing I can hear the car shift it just does not move. I turned the car off and started it back up and was shot tonget home. Parked the car went back out to leave..... same issue. I can hear it going into all years but it doesn't move. If I shut off the engine and start it again all the gears work fine for about 3-5 miles then nothing. Looked for leaks and found none. The fluid level is fine. I'm completelt stumped never had anything like this happen especially how it will go after turning off and restarting the engine. Also it's reading no codes. Any feed back would. E greatly appreciated
    thanks
    adam
  2. #2 Re: In gear won't move
    you'll need to scan it for codes while its running to see if theres a pending code. once you shut the car off the code clears and the tranny works again. once its acts up scan it.
  3. #3 Re: In gear won't move
    New York
    Thanks I actually just did that this morning it's not coming up with any codes. When I **** it into gear I can see the motor pivot like it normally would when going into r or d. Even tried using it with the "slap shift" still nothing. Never seen anything like it. Hoping with it doing everything it normally does other than moving that it's not a tranny issue.
  4. #4 Re: In gear won't move
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Hmm.. is the parking brake stuck, or it's more immovable than that?
    I'd also say it ****'s outta gear, but maybe that's just me.
  5. #5 Re: In gear won't move
    New York
    Well it's magically going into gear now. But if I give it any sort of umpff or try to start moving on a hill it stutters like an SOB. After first gear it's fine and so far if I use the slap shift it seems better isk where to look and I don't want to just dump useless money into it
  1. 1st Gear Revs After Acceleration Before Engaging Second Gear
    By geeteezee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2016, 08:27 PM
  2. gear set, 4th gear hub, channel plate gouged! help!
    By kawasaki22106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-05-2013, 04:54 AM
  3. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  4. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
