Not sure where you are located, but check the junkyard sway bar good before removing for any signs of rust. While this is a very good and cheap alternative to buying new this job is quite a pain for a novice. Most likely the cradle has to be dropped in the rear a few inches if you cant snake it in there, at least it did when I installed the Dorman on the Impala(should be the same). I've been wrenching for 30 years, and it isn't a fun job but totally doable for anyone with the time and tools. Then you get to repeat the process on your car.
