Thread: Rear Inner Tie Rod
Results 1 to 3 of 3
  1. #1 Rear Inner Tie Rod
    Sep 2015
    Baton Rouge
    I have a 1998 Grand Prix 3.6.
    Took it in for an alignment and the guy said my passenger side rear tie rod is bent.
    I thought tie rods were on the front?
    How hard are they to replace? Is it the same tie rods that go on the front? All I can find part wise seems to indicate they are for the front.
    Thank you folks for any help.
  2. #2 Re: Rear Inner Tie Rod
    http://www.amazon.com/Dorman-905-501.../dp/B001DRO4K6
    you have 3 bars per side that align the back tires. trailing arm is the most common one to be bent. its in the ad, then the other two bars are in the bottom links.
  3. #3 Re: Rear Inner Tie Rod
    Likley it's the rear toe link.
    FWIW you shouldn't have a 3.6L either.
  1. Replies: 41
    Last Post: 05-01-2015, 01:45 AM
  2. Replies: 1
    Last Post: 04-22-2013, 11:32 AM
  3. Replies: 20
    Last Post: 03-26-2013, 11:05 AM
  4. Rear STB only...
    By a3gtp in forum Brakes/Suspension/Chassis
    Last Post: 03-08-2009, 06:17 PM
