Thread: Vibration?
Results 1 to 3 of 3
  1. #1 Vibration?
    Banned
    Jan 2013
    maryland
    driving my car yesterday i felt vibration around 50mphs and it goes away once i hit 60 my tires were balanced and rotated and i have a alignment done so i ruled out my tires being the culprit.. Replaced hubs.. Tie rod ends.. New solid sway bay .. Brakes rotors.. But i do have lowering springs could that cuz the issue? Axles? Thanks guys
    Sent from my LG-D851 using Tapatalk
  2. #2 Re: Vibration?
    St. Louis
    Could be the axles. How long have the springs been in? If it's been a while and everything was ok at install then I'd bet the suspension geometry is off due to the springs and you need a spacer to bring the driveline back into spec, along with some new axles since they are now toast due to excess wear/angle.
    The only other thing that comes to mind is engine and trans mounts. If they are shot then it could screw up the drivetrain since everything would be sitting lower.
  3. #3 Re: Vibration?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by FordMan77 View Post
    Yea idk man its probably possible that the axles may be shot.. Trans and motor mounts are replaced with poly mounts so .. Thats gonna be my next replaced part for the car
  1. Vibration?
    By cavell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2013, 03:31 PM
  2. help vibration
    By shawnheck03gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 06:03 AM
  3. bad vibration under wot
    By shawnheck03gtp in forum General Tech Discussion
    Last Post: 10-08-2009, 09:03 PM
  4. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  5. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
