Thread: struts and lowering springs
Results 1 to 15 of 15
  1. #1 struts and lowering springs
    Aug 2015
    Austin Texas
    Im new to this site but am in need of some input, I have a 2004 grand prix gt2 and I want to put some lowering springs on the car as well as new struts. i have been looking at the ssc lowering springs from zzp.com and the agx struts but the info on the struts says that the agx will not fit the front of my car. does anyone have any suggestions on what to go with? I only have a budget of about $600.
  2. #2 Re: struts and lowering springs
    AGX are kinda overkill.
    KYB GR2 work fine for a decent quality strut.
    Look up canuck motor sports, they make the SSC springs. They should be cheaper through them, than buying from ZZP. Also note that is should ride nearly like stock but with some extra bounce/pogo from time to time because of the springs they are. Anti pogo washers do help but it can't get rid of all of it.
  3. #3 Re: struts and lowering springs
    Let's begin
    97-03 and 06-08 the endlinks connect from the control arm to the sway bar
    On
    04-05 the endlinks connect from the strut to the swaybar. The 04-05 type strut have tabs on them where the endlink attached to.. The front struts meant for the 97-04 don't have this tab that's why without further parts they won't work.
    Now what you can do is pick up a set of 97-03 or 06-08 style control arms and swap them but you will also need endlinks from that year as well as a swaybar.. Then you can run whatever strut you'll like on the front.
    Questions?
    04 Comp G.
  4. #4 Re: struts and lowering springs
    Aug 2015
    Austin Texas
    Ill go look them up i know i was looking at the gr2 struts awhile ago but didnt know what to go with. also will these springs and struts hold up if i have a large stereo setup in the trunk? i have 2 rockford t2 subs and a battery plus 2 amps. i know the ssc springs say that they guarantee no sag but thats a lot of weight. if it sags could i put a spacer after the mount
  5. #5 Re: struts and lowering springs
    Aug 2015
    Austin Texas
    thank you
    i guess i will be going to get some different control arms, would i be better off to go with the older ones or newer? are the agx better than the gr2? im looking for a better ride since right now my stock struts and springs are giving me crazy body roll going around curves and corners hard.
    also do you know where to find strut bar braces for the front and rear of my car? i can find them for the front but not the rear.
  6. #6 Re: struts and lowering springs
    The strut bar is the same for both the front and rear so just grab two. If your needing the brackets themselves so that don't have to drill into the strut towers then drcustomparts.com
    04 Comp G.
  7. #7 Re: struts and lowering springs
    I believe the control arms are still the same..I'll either grab a set from the JY for cheap from the JY and replace the bushings with Moog problem solving ones. Then grab a Dorman front swaybar.
    04 Comp G.
  8. #8 Re: struts and lowering springs
    Enfield, CT
    Let's begin
    On
    Questions?
    Hey Bud, just so you know the 06-08 years were mixed when it came to the sway bars.
    My 06 sway bar was linked to the strut but I put the 97-03 control arms on to run the 34mm GMPP sway bar.
  9. #9 Re: struts and lowering springs
    Yup.. That's a in general statement I still recommend peaking in the wheel well and seeing what setup you have. Surprise surprise GM probably used leftover parts.
    04 Comp G.
  10. #10 Re: struts and lowering springs
    Aug 2015
    Austin Texas
    thank you for the help im definitely looking forward to getting them ordered
  11. #11 Re: struts and lowering springs
    Aug 2013
    McDonald PA
    Quote Originally Posted by SINISTER1988 View Post
    Not sure how your system will like sscs
  12. #12 Re: struts and lowering springs
    Enfield, CT
    No but okay lol
    Sent from my LG G3
  13. #13 Re: struts and lowering springs
    Aug 2013
    McDonald PA
    Quote Originally Posted by HighOctaneRacing View Post
    No but okay lol
    Sent from my LG G3
    What? My 06 has 05 parts on it.
  14. #14 Re: struts and lowering springs
    Enfield, CT
    Like what?
    Sent from my LG G3
  15. #15 Re: struts and lowering springs
    Aug 2013
    McDonald PA
    Like what?
    Sent from my LG G3
    The struts mainly as far as I noticed.
  1. What needs done to remove Lowering Springs and go back to stock springs?
    By NotEnoughGPs in forum Brakes/Suspension/Chassis
    Last Post: 05-19-2015, 09:49 PM
  2. For sale lowering springs an struts
    By Deanpope2 in forum For Sale - Parts
    Last Post: 01-30-2015, 07:09 PM
  3. Lowering springs stock struts having to mod holes?
    By DrSnazzy in forum Brakes/Suspension/Chassis
    Last Post: 08-07-2013, 08:04 AM
