Thread: New Struts question
Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 83
  1. #41 Re: New Struts question
    Chicago
    Quote Originally Posted by Grandprix202 View Post
    I think i should be ok... Does anyone know what would need to be transferred over from the old struts... I know probably that rubber accordion thing and thsts all I can think of
    Sent from my SM-N900P using Tapatalk
    I think someone mentioned this before but there are several wear items that should be replaced or at least I did when doing mine. E.g. Strut, strut boot, strut mount, coil spring insulator. I believe that's it but I would need to check my receipts later to be sure since its been a while. I reused my old springs when I did mine. The KYBs (GR2) will not accept the original GM boot so that's why I ordered new ones. Actually my old boots were fine and a are far superior to the ones KYB sells. Not sure if they have improved.
    btw, the rubber accordion thing is the boot.
  2. #42 Re: New Struts question
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    I knew someone said something about it but I didn't know exactly what the wearable parts were so thank for explaining. Coil spring insulator... What is that
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  3. #43 Re: New Struts question
    Chicago
    Actually there are two insulators. A lower and an upper. They basically isolate the spring from the metal strut body on the bottom and the strut mount from the top.
    Here are the KYB part numbers when I ordered my KYB GR2s. Please double check their accuracy since I am going off of my notes from over three years ago. Btw, check Amazon, Rock Auto and even the Tire Rack when pricing individual parts out.
    Front strut - 339015
    Front strut mount - SM5568
    Front strut insulator (upper) - SM5467
    Front strut insulator (lower) - SM5437
    Front strut boot - SB127
    Hope it helps...
  4. #44 Re: New Struts question
    Apr 2013
    Fowlerville
    Thanks to SO much. This is exactly what I was looking for. It doesn't matter for driver or passenger side right?
  5. #45 Re: New Struts question
    Chicago
    No there is no difference in front from what I recall. The mounts in the rear are unique to each side though.
  6. #46 Re: New Struts question
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Quote Originally Posted by zguy View Post
    Rock now has KYB SM5568, which is the mount kit that includes the mounting plate, the bottom isolator, and the bearing (top isolator) for $23.79. Add in $58.79 for the strut and you're at $82.58 vs a completely assembled strut with new spring for $104.79. So for an extra $22.21 I get a new spring and don't have to fool with the compressor, etc.
  7. #47 Re: New Struts question
    Apr 2013
    Fowlerville
    With struts, front and rear mounts, boots, upper and lower insulator, and Springs comes out to 683... I think I might just get the quick because I really don't have that cash right now haha
  8. #48 Re: New Struts question
    Dec 2008
    ****'s Creek
    Get all 4 KYB complete struts on Rock for like $400 plus shipping, use the 5% discount posted on the general forum
    Sent from my SPH-L720 using Tapatalk
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  9. #49 Re: New Struts question
    Apr 2013
    Fowlerville
    They only have the back kyb
  10. #50 Re: New Struts question
    Apr 2013
    Fowlerville
    There are only the back two in kyb on rockauto. Should I get back kyb and front Monroe?
  11. #51 Re: New Struts question
    Aug 2013
    McDonald PA
    no check amazon
  12. #52 Re: New Struts question
    Apr 2013
    Fowlerville
    Hopefully ordering theses tonight
  13. #53 Re: New Struts question
    Donating Users seventone's Avatar
    Mar 2013
    midwest
    i got some moog struts from summit.
    http://www.summitracing.com/search/y...rder=Ascending
    1997 Black GTP Coupe | 1997 Black GTP Coupe | 2001 Silver GTP Coupe | 2001 Red GTP Coupe
  14. #54 Re: New Struts question
    Dec 2008
    ****'s Creek
    I would stay same struts all around dont mix and match
  15. #55 Re: New Struts question
    Apr 2013
    Fowlerville
    How did you like those... I'm kinda leaning towards KYB.
    Amazon obviously has them but I can't check the part number becuase they aren't on rock auto.
  16. #56 Re: New Struts question
    Dec 2008
    ****'s Creek
    I like them. Lots more control but not too harsh. For 97-03 fronts are sr4002, rt rear is sr4903, left rear is sr 4004.
  17. #57 Re: New Struts question
    Dec 2008
    ****'s Creek
    Sorry thats 4003
  18. #58 Re: New Struts question
    Apr 2013
    Fowlerville
    I gotcha! Thank you very much. Gunna order the fronts off amazon and the backs off rock to save 20 bucks
  19. #59 Re: New Struts question
    Mar 2013
    midwest
    I have the moogs all around and they feel great but its sitting a little high i am hoping they settle in.
    If they do not i am going to put on some B&G springs.
  20. #60 Re: New Struts question
    Apr 2013
    Fowlerville
    466 from Amazon
  1. struts equal to GM konis struts
    By Dee23 in forum Brakes/Suspension/Chassis
    Last Post: 05-17-2015, 02:47 AM
  2. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  3. question on struts
    By gtcoup in forum Brakes/Suspension/Chassis
    Last Post: 07-14-2011, 05:30 PM
  4. Question about prior gen struts
    By MissChelsea in forum Brakes/Suspension/Chassis
    Last Post: 03-30-2011, 04:21 PM
  5. Question on struts
    By basshead42 in forum Brakes/Suspension/Chassis
    Last Post: 03-22-2009, 11:28 PM
