Thread: Car shaking 02 gtp
Results 1 to 15 of 15
  1. #1 Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    I have an 02 GTP and when I get to 38 to 45 mph my car starts to shake from the driver side tire. When I pass 45mph it stops until I get to 73mph. The outside of the tire on the driver side is almost bald but the rest of the tire is good. What could be causing this issue? I'm going to get a rotation and balance of tires today and see if that helps
  2. #2 Re: Car shaking 02 gtp
    Sep 2014
    Worcester, MA
    If the outside of the tire is bald, you might want to have them check your alignment too... and ball joints.
  3. #3 Re: Car shaking 02 gtp
    get an alignment, also make sure they look the front end over. some thing could be real worn out.
  4. #4 Re: Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    I was told to get control arms
  5. #5 Re: Car shaking 02 gtp
    those kill 3 birds at once. both bushings and the ball joint.
    if you buy them on line the pair is just under a 100 bucks. they are pretty easy to change your self.
  6. #6 Re: Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    You have a site to get those at? Cause the ones I saw were 70ea and come with the bushings and joints. They are moog brand
  7. #7 Re: Car shaking 02 gtp
    rockauto. partsgeek. advance auto on line. all run a little more for moog parts, those are like 55 to 60 iirc. shop around. google your car and lower control arms, a crap load of places will pop up.
  8. #8 Re: Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    I'm using rockauto right now and the ones that are 70 come with a gusher bearing. Is that really needed?
  9. #9 Re: Car shaking 02 gtp
    pic or link to the part. im not sure wtf that is.
  10. #10 Re: Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    Well I got my tires rotated and the problem moved. So looks like I need a new rim and tire
  11. #11 Re: Car shaking 02 gtp
    Is the rim really bent or is the tire just seperated??
  12. #12 Re: Car shaking 02 gtp
    St. Louis
    If the front tire was bald on the outside, and you moved it to another spot and it followed then the tire is junk. And most likely something(s) are worn out on the front end, be it LCA, ball joint, tie rod, or the alignment is way off. I'd bet the tire you just moved to the front is going to have a similar fate.
  13. #13 Re: Car shaking 02 gtp
    Jun 2015
    Sheboygan,WI
    I'm getting the front control arms then new tires and alignment. All this should be done this week hopefully. https://www.rockauto.com/catalog/mor...id=443&jpid=13
    This is the link to the control arm. Any good?
  14. #14 Re: Car shaking 02 gtp
    Apr 2015
    Columbus, OH
    Yep. 66 bucks on Amazon too.
    Top Swapped 01 Imp
  15. #15 Re: Car shaking 02 gtp
    Oct 2013
    michigan
    I had a junk half shaft causing something similar.
    01 gtp SD headers. gen V swap. hai. zzp 1.0 pcm. 06 Impala brakes. GMPP sway bar.
    01 ram 2500 870hp/1796lbft fmw s467.7 w/n20 old. new 66/86 compounds ????hp/????lbft.
  1. shaking at 50-60 mph HELP!!!
    By pink1221 in forum Brakes/Suspension/Chassis
    Last Post: 11-01-2011, 12:36 PM
  2. Shaking....
    By ljmonnin12 in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 11:23 AM
  3. Still shaking
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2010, 06:14 PM
  4. Car is shaking
    By Warlord55 in forum General Tech Discussion
    Last Post: 10-26-2010, 09:28 PM
  5. 02 GTP shaking
    By y2ed in forum General Tech Discussion
    Last Post: 09-27-2010, 03:19 PM
