Thread: Rocker Panel Question
Results 1 to 3 of 3
  1. #1 Rocker Panel Question
    May 2015
    Calgary, Alberta, Canada
    Hi all,
    Looking to get some input on my rocker panel... It is just the drivers side rocker that has rusted, passenger side just has some very minor surface rust. A body shop to fix this in Canada would cost way to much, so hopefully I can get some input on how to at least stop the rust from going any further. I am pretty inexperienced with body work, so any help is appreciated.
    Thanks
  2. #2 Re: Rocker Panel Question
    That lip piece will always rust away first, you need to take the side skirt off to really see how bad the rockers are.
    Either there will be no holes/no rust or there will be lots of rust and big holes.
    I can't see the bottom of the car from these pictures, but if there are holes to the left of the pinch weld then stopping the rust is going to be very hard without cutting all the metal out.
  3. #3 Re: Rocker Panel Question
    May 2015
    I had a good look underneath, and found no holes or rot anywhere. Would it still be recommended to take off side skirt? With regards to the lip... Is it too late to save it, or in order to fix/stop spread would I have to cut that portion out?
  1. rocker panel or quarter panel??
    By ad356 in forum General Tech Discussion
    Last Post: 12-08-2013, 08:42 AM
  2. rocker panel rust
    Last Post: 12-06-2013, 01:19 AM
  3. rocker panel question PLEASE HELP!
    By jbuckygtp in forum General Grand Prix Discussion
    Last Post: 07-07-2012, 10:11 PM
  4. rocker panel issues
    By stok3z in forum General Grand Prix Discussion
    Last Post: 04-25-2012, 04:25 PM
  5. I got new rocker panel moldings!!!!!!!!!!
    By Doug 97 gtp in forum Visual/Body Modifications
    Last Post: 04-24-2012, 12:11 AM
