Thread: budget suspension replacement
Results 1 to 17 of 17
  1. #1 budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Hello, everyone. It has been a while since I've posted being busy closing on a new house, but I have a question/want some opinions. My 1999 GP SE's ride has lately getting rougher and rougher. Thinking it is time to replace some of the suspension but I wanted to ask everyone's opinion on a budget setup. It feels like the rear end is sloppier than the front and depending on the road, I have an almost POGO effect in the ride. I'm not sure if my front strut tower brace is causing this or if it is something else.
    Going to be moving into a new house and I only plan on keeping the car for another 6-8 months, hence why I want to go as inexpensive as possible for the replacement parts. I'm thinking rear sway bar and 4 new quick-struts for sure. Any other suggestions while I have the car apart?
    Thanks in advance; as usual this forum is super helpful!
  2. #2 Re: budget suspension replacement
    St. Louis
    Leave the rear sway alone. Most likely just worn out struts. Check RockAuto, Amazon, Partsgeek and Ebay for prices. I've got quite a few things pretty cheap through Amazon lately.
  3. #3 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Think just the struts are needed?
  4. #4 Re: budget suspension replacement
    Yeah I would just do struts and springs. The rears are really bad with wanting to sag.
  5. #5 Re: budget suspension replacement
    St. Louis
    And don't forget to change all the strut mounts. Likely those are junk too.
    Grab a can of PB Blaster and soak down all the nuts/bolts ahead of time. You'll thank me later
  6. #6 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Is the rear struts are whats causing that "sloppy" feeling? What are the strut mounts you are talking about? Thanks everyone for the help.
  7. #7 Re: budget suspension replacement
    St. Louis
    The sloppy feeling is likely all the struts being bad. You're basically riding on just the springs with no rebound/dampening control from the strut. If it feels like driving an actual boat on water, then it's the struts.
    The strut mount is what sits on top of the strut and bolts to the car body. Has the large nut in the center of it.
  8. #8 Re: budget suspension replacement
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    As long as the rear sway isn't broken leave it be.
    The non econo line quick struts are what I have on my car are what I recommend. You don't need to worry about mounts as they come with.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  9. #9 Re: budget suspension replacement
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I bought kyb quick struts off amazon for right around $400 shipped. They are completely bolt in and really easy to install. I would recommend them.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  10. #10 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Alright, thanks guys. You probably saved me a couple hundred bucks on unnecessary parts.
  11. #11 Re: budget suspension replacement
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    I found a pair of rear Monroe quick struts on Craigslist for $80. A round of haggling later and I got them for $50... and they made a world of difference on my car. Trust me you can't go wrong with even that cheap of a replacement
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  12. #12 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    That isnt bad. Im hoping to get another 6 months out of this car but the ride is getting unbearable. Havent decided if im going to replace it with a gtp or just get the truck i want lol. Just bought a house so the truck could be more useful.
  13. #13 Re: budget suspension replacement
    Newnan, GA
    ^gtp with a hitch.
  14. #14 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Quote Originally Posted by EJOUIE View Post
    ^gtp with a hitch.
    Hahaha more like i need the truck bed for my trips to Menards or Home Depot.
  15. #15 Re: budget suspension replacement
    Apr 2015
    Columbus, OH
    Wudduya think them roof rails and fold down seats are for?
    Top Swapped 01 Imp
  16. #16 Re: budget suspension replacement
    Apr 2015
    Columbus, OH
    Or like this
    Top Swapped 01 Imp
  17. #17 Re: budget suspension replacement
    Jan 2013
    Sioux Falls, SD
    Definitely a fail haha
  1. suspension replacement questions..
    By andremike in forum Brakes/Suspension/Chassis
    Last Post: 08-03-2017, 03:51 PM
  2. 12 sec budget GTP
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 06-11-2013, 09:20 AM
  3. suspension replacement
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 10-30-2009, 10:13 PM
  4. Perfomance on a budget?
    By jasonball in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2009, 11:50 PM
  5. Replacement suspension
    By blakshukvw in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2009, 02:24 AM
