Thread: need some help troubleshooting
Results 1 to 6 of 6
  1. #1 need some help troubleshooting
    Dec 2011
    colorado
    OK the problem I am having is I am trying to build boost (on a turbo car) while sitting at the light so I can leave under some power and not have to wait for the turbo to spool. The problem is the brakes won't hold the car from rolling. I can get to where I'm almost starting to build boost but then it starts breaking loose and rolling a little.
    Does anyone have any advise on what I could do or start checking. Only thing I know is to bleed the brakes. So I will be doing that but was wondering if there could be other issues.
    Thanks mike
  2. #2 Re: need some help troubleshooting
    get f body brakes up front?
  3. #3 Re: need some help troubleshooting
    Miles and year of car?
    If original brake hose and fluid, I'd swap those out for sure. You could lose alot of pressure in the system with worn out hoses/old fluid/worn calipers.
    Poor shape brake rotors and cheap pads in the other problem for most.
  4. #4 Re: need some help troubleshooting
    Antioch, IL
    toss the turbo, problem solved
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: need some help troubleshooting
    Dec 2011
    colorado
    Got c5 calipers with f body slotted rotors in front. GXP calipers and slotted rotors in back. And steel braided lines all the way around. It's on a 2000 gtp.
  6. #6 Re: need some help troubleshooting
    give it less gas then.
  1. A/C Troubleshooting
    By TheInterloper in forum General Tech Discussion
    Last Post: 06-28-2012, 02:15 PM
  2. Need help troubleshooting my A/C
    By buck in forum General Tech Discussion
    Last Post: 09-16-2011, 09:34 PM
  3. Troubleshooting Help
    By Bigkamp22 in forum General Tech Discussion
    Last Post: 11-09-2010, 03:14 PM
  4. need help troubleshooting
    By tmans01gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2010, 04:48 PM
  5. DIC troubleshooting
    By skidoojames151 in forum General Tech Discussion
    Last Post: 05-15-2010, 09:39 PM
