Thread: suspension ??
Results 1 to 17 of 17
  1. #1 suspension ??
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    what do most people recommend for a set of struts and lowering springs ? also anything else that might be needed while doing all this ? i have seen coil over set ups and i use to use them on most my other cars . do the struts and spring come out as 1 piece or do i need a spring compressor when taking the suspension out ? that is why i was thinking just buying new springs and struts together and not worrying about the spring compressor .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: suspension ??
    PA
    Probably one of the best setups, as far as I am concerned, is the KYB AGX strut with the Vogtland springs on them.
    But it all depends on what you are looking for. This will only give about a 1" drop. If you want more, you will have to go with another brand of springs.
    If you buy new springs and new struts, and new mounts (highly recommended), you can also buy new boots and insulator pads and just make a whole new drop in assembly. And when using lowering springs, you shouldn't need to get spring compressors. So you could just pull the old ones out, and put in the entire new setup that you assembled.
    If you had planned on reusing some of the old components, then you would need a set of spring compressors to remove the old, stock springs. But even if you needed to do this, a set of compressors can be had for less than $20. And even still, you can rent them from most parts stores for free.
    2001 GSE
  3. #3 Re: suspension ??
    ^^^^^^^ agree!!!!!!!!!^^^^^^^^^^^^^^^^ for the performance and ride vogtland are #1 !
  4. #4 Re: suspension ??
    Milpitas , Ca.
    sorry posted in the wrong area . thanks for moving it .
  5. #5 Re: suspension ??
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    you need some way to correct your suspension geometry. if you dont do anything, you will experience vibrations at a given rpm.
    you either need to shim the motor, or shorten the half shafts...but you cant let it be.
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  6. #6 Re: suspension ??
    Milpitas , Ca.
    Quote Originally Posted by scooz14 View Post
    what about the shortened dogbones ???? wont that do the same thing ??
  7. #7 Re: suspension ??
    SE Level Member JashGTP's Avatar
    VA
    Held coilover FTW!
    I have a thread with some pics and i need to update it with some new pics.
    But ride is great and ability to adjust is great.
    Slam it for shows. Raise it a bit for DD/ road trip.
    Raise the rear all the way 2.5+" above stock for the track.
    Costs a bit more it has totally been worth it, particulary for install wise.
    Took literaly no time at all. It is only 10 bolts in the front and your done.
  8. #8 Re: suspension ??
    Milpitas , Ca.
    i have been meaning to ask you were you got your coil overs from ? any vibrations that you get ?
    Quote Originally Posted by JashGTP View Post
    Held coilover FTW!
  9. #9 Re: suspension ??
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Wouldn't pogo washers help w/ this also? or is that just a ghetto fix?
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  10. #10 Re: suspension ??
    West Bloomfield MI
    that stops the car from bouncing like you have blown struts when you go over bumps
    im talking about the angle change in your half shafts. yes, they are designed to flex to that angle, but they are desinged to return back to standard ride height. lowering the car makes the half shafts slightly longer, causing premature axel failure, and vibrations.
    329.9hp 400.1tq
  11. #11 Re: suspension ??
    alhambra, Il
    ahhh. I see. thats is good info to have.
    Steven Oliver
  12. #12 Re: suspension ??
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    The rest of the good info is I'm the one who makes the engine mount spacers, or shims as they have been called.
  13. #13 Re: suspension ??
    alhambra, Il
    Haha, nice plug there. No seriously though that actually is good info to have.
    Steven Oliver
  14. #14 Re: suspension ??
    Port Hope Ont,Canada
    Are these the spacers that raise the engine up some ?
    I have KYB and Eilbah Pros and went in for a aignment
    and they said why ?
    The car is sitting fine..
    I said well i just had it lowered and will need one.
    Car rides like a caddy on smooth pavement...
    Just that smooth pavement don't last long...
    The KYB's and Pro's is a rough ride---> steer clear
    I love the drop it gives but would not ever go this way again
    and once i get these off they are going str8 to the garbage,
    as i could never sell these after riding on these myself...CRAP
    By the way everything was brand new
    even the boots and po go washers...
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  15. #15 Re: suspension ??
    Las Cruces, NM
    Those are the spacers....
    I used t orun Eibach Pro Kit with GR2's. I didn't know how bad it was till I got AGXs.
  16. #16 Re: suspension ??
    GXP Level Member ryangtp89's Avatar
    Maine
    Idk what it was but when i was outside shoveling, i was thinking about some kind of police suspention for the gp, like take the suspention from a police impala or something, idk if that would work, or if its any better then the one we have in it now or or not. It was probably my brothers friend's crown vic police intercepter. I wounder if my gtp could smoke that with just a cai on it. I probably could maybe off the line, but not for top speed cause i kno they go up to 140.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  17. #17 Re: suspension ??
    Las Cruces, NM
    What you are suggesting, GM has already put together for us. Its the GMPP suspension kit.
    We used to have to piece it together piece by piece but they called it something different and packaged it up to make it easier to find.
  1. Suspension section
    By hydro1110 in forum Forum Bugs/Suggestions
    Last Post: 01-05-2008, 12:56 AM
  2. Suspension Tech
    By GS-SC in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 02:35 PM
