Thread: Building Strut Assemblies?
Results 1 to 5 of 5
  1. #1 Building Strut Assemblies?
    Jan 2013
    Texas
    Thinking about getting some new struts for my 02 GTP and trying to figure out if it would be cheaper to build your own strut assembly are just buy a fully complete one. Don't really want lowering springs cause my damn down pipe is low enough to start scrapping after going over speed bumps, just want a higher spring rate. If building your own would be cheaper, what parts do you need?
  2. #2 Re: Building Strut Assemblies?
    You can just build your own.. Replace the mounts and strut and reuse the rest of the hardware from the old stock struts.. Hardware still should be in good condition. Then if your just wanting to up the spring rate.. I believe the comp g springs have a higher rate without lowering the vehicle.
    04 Comp G.
  3. #3 Re: Building Strut Assemblies?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    I bought kyb quick struts for about 425 shipped for all 4 and I like em.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Building Strut Assemblies?
    Price out a set of whtever struts you want to go with and then a set of mounts then figure out how much of your time it's worth to swap the old hardware from one to another then go from there.
    04 Comp G.
  5. #5 Re: Building Strut Assemblies?
    Jan 2013
    Texas
    if i want to build rear struts, do i need everything thats on the front ones like spring seat and insulators?
  1. 2000 GTP Stock Strut Assemblies - $40
    By G8GTChick in forum For Sale - Parts
    Last Post: 11-20-2014, 04:54 PM
  2. Replace KYB Strut-Plus strut with Bilstein?
    By nik12937 in forum Brakes/Suspension/Chassis
    Last Post: 01-20-2014, 04:58 PM
  3. Monroe Quick Strut vs. KYB Strut Plus...definitive?
    By FRESCOLIO in forum Brakes/Suspension/Chassis
    Last Post: 09-30-2009, 05:27 PM
