Thread: Replacement springs advice for 05 GTP
Results 1 to 20 of 20
  1. #1 Replacement springs advice for 05 GTP
    Dec 2013
    Rochester, NY
    Hey everyone. I'm getting ready to replace all four struts on my 05 Grand prix but i'm stuck on new springs. I'm going to run the KYB Excel G's for all four but i want to get stiffer springs as well instead of new stock ones. What would everyone recommend i check out? Thanks.
  2. #2 Re: Replacement springs advice for 05 GTP
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    97-03 spec SSC/Canuk springs if you want to lower.
    Impala police springs if you want a stock ride height
    Email all inquiries to willoverkill@gmail.com!
  3. #3 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    Will 97-03 lowering springs work on the 04-08 body style?
  4. #4 Replacement springs advice for 05 GTP
    Yup
    04 Comp G.
  5. #5 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    Is that a yes?
  6. #6 Re: Replacement springs advice for 05 GTP
    Yes!!
    04 Comp G.
  7. #7 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    Thank u.
  8. #8 Re: Replacement springs advice for 05 GTP
    No problem
    04 Comp G.
  9. #9 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    Do u have them?
  10. #10 Re: Replacement springs advice for 05 GTP
    Have what?
    04 Comp G.
  11. #11 Re: Replacement springs advice for 05 GTP
    Aug 2013
    McDonald PA
    Quote Originally Posted by gambler87 View Post
    Do u have them?
    Have what?
    Nope reds a coke dealer not a spring dealer.
    Cannuck motorsports will have them. Google them it'll be cheaper than zzp even with shipping.
  12. #12 Re: Replacement springs advice for 05 GTP
    Lmao wow you just had to go there
    04 Comp G.
  13. #13 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    I was wondering if u have 97-03 springs on ur comp g
  14. #14 Re: Replacement springs advice for 05 GTP
    Sort of.. What's on there currently are the DNA springs that are advertised as 97-03. 97-03 and 04-08 parts are mostly compatible as far as motor and suspension wise.
    04 Comp G.
  15. #15 Re: Replacement springs advice for 05 GTP
    Dec 2013
    laporte mn
    OK I have an 04 comp g and I'm looking of r lowering springs so I was wondering what kind of options I had. Thanks for the info
  16. #16 Re: Replacement springs advice for 05 GTP
    SSC or Vogtlands would be your best choice unless you go the coilovers route.
    04 Comp G.
  17. #17 Re: Replacement springs advice for 05 GTP
    Mar 2015
    Tampa, FL
    just out of curiosity, how much stiffer are the impala cop car springs?
  18. #18 Re: Replacement springs advice for 05 GTP
    Dec 2013
    Rochester, NY
    Where can I get the impala police springs?
  19. #19 Re: Replacement springs advice for 05 GTP
    Nov 2012
    Madison
    I have 04-08 SSCs on my compg...the 97-03 don't lower the rear as much.
    If I would do it over, I would order the 97-03s. They would make the fender wheel gap,front and back, more even.
    It isn't to bad with the 04-08s but after awhile the look will get to you, with the rear appearing to low.
    I would think Overkill has seen a fair number both ways.
  20. #20 Re: Replacement springs advice for 05 GTP
    Dec 2013
    Rochester, NY
    Where can I get the police package springs and would they increase the ride height on the car?
  1. Replies: 29
    Last Post: 07-24-2013, 03:50 PM
  2. Replacement time looking for advice
    By TeacherCreature in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2013, 06:59 AM
  3. Advice on lifter replacement
    By goldgp in forum General Tech Discussion
    Last Post: 02-12-2011, 08:51 PM
  4. Advice on gasket replacement
    By ajnelson4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2010, 12:46 PM
  5. Seeking Advice about Lowering Springs/Rims
    By mRa in forum Visual/Body Modifications
    Last Post: 04-10-2010, 11:55 PM
