Thread: Broke Spring
Results 1 to 2 of 2
  1. #1 Broke Spring
    SE Level Member trailshredder's Avatar
    Feb 2009
    Central Ohio
    I broke a front Strut Spring today on my 02 GP GT. My car has always squatted a little in the rear, compared to the front. I found a set of lowering springs on ebay that I was considering doing on both fronts. Says it will drop the front 1.7 inches. Will I have tire rub issues with stock rims and tires? Is it safe to say the distance between the tire and fender well will decrease 1.7"?
    02 Grand Prix GT, Silver with all options.
  2. #2 Re: Broke Spring
    Figure the drop wont be 1.7 but maybe 1.2-1.4in for a long time, then they might sag as they age.
    The ride quality won't be as good either but that comes with lowering. You won't rub with stock rims and tires.
    I'd research more on lowering, you might want to see what else might happen. Be it with clunks, anti pogo washers and motor mount spacers to reduce driveline vibrations.
  1. I Think I Broke It ...
    By stok3z in forum General Grand Prix Discussion
    Last Post: 11-03-2012, 04:51 PM
  2. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  3. Rear Spring broke - 2000 GTP
    By Tfreeds in forum Brakes/Suspension/Chassis
    Last Post: 02-07-2010, 01:59 PM
  4. I broke it!
    By The_Avenger in forum General Tech Discussion
    Last Post: 07-27-2008, 09:31 AM
