Thread: Axle shaft removal help
Results 1 to 5 of 5
  1. #1 Axle shaft removal help
    SE Level Member 95Fummins's Avatar
    Dec 2014
    Goodland,Ks
    Replacing cv shaft on driver side of my GTP and it will not come out. I have tried the special tool for the slide hammer, prybars, and screw drivers and it will not pop out of the transmision. Somebody help...
  2. #2 Re: Axle shaft removal help
    gardner,mass
    Just get a pry bar on the back side of it and give it a quick smack. What i meen is dont try to pry and pry you need to pop it out.
    This is what you need
    http://www.harborfreight.com/16-inch...bar-31383.html
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Axle shaft removal help
    Dec 2014
    Goodland,Ks
    I have not tried a heel bar I'll have to give that a shot tomorrow. But I have been trying to "pop" it out not just continuously prying( witch I have also done out of distress) but there is just no good way to get at this driver side shaft, I did the passenger side about a month ago without of a hitch. And that slide hammer gave it a good jerk it and it won't budge.
    2000 GP GTP, 2dr. W/ performance shift Cold air, 160 stat,autolites, aluminum elbows,3" downpipe full 3" exhaust,headers,3.4 pully, tunes, ported housing,poly mounts, larger idler,w body axle shafts, hd convertor, shift kit,18" American racing wheels, 12" type R subs poly box, all alpine speakers and head unit.HIDs 14.9 1/4
  4. #4 Re: Axle shaft removal help
    Dec 2014
    Goodland,Ks
    I have heard tell that if you take the passenger side out you can maneuver around the differential and drive it out but I'm not to excited about taking the other side back apart.
  5. #5 Re: Axle shaft removal help
    well..that's what I just pm'd you .. lol
  1. Transmission axle shaft??? maybe called output shaft.
    By tommygunz12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2014, 06:49 AM
  2. Axle Shaft Seal?
    By Klutch in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2009, 11:02 AM
  3. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  4. Axle removal problems...please help!!
    By copgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2008, 02:59 AM
